why droplet is not formed in micro channel
Old   May 23, 2014, 01:02
Default why droplet is not formed in micro channel
taajaki is on a distinguished road
Hi Foamers.
I am trying to simulate a micro channel and I expect to see droplets in it but as you can see here the droplets are not formed . Blue color is oil(continuous phase) in main channel and the red one is water (dispersed phase) which is flow in two lateral channels.(I have two lateral channel and one main channel).
Is there any comment ?
thanks for your attention
these are boundary conditions :
alpha.water
boundaryField
   oil
        type            fixedValue;
	value		uniform 0.0;
    water-1
        type            fixedValue;
	value		uniform 1.0;
     water-2
        type            fixedValue;
	value		uniform 1.0;
   outlet
        type            zeroGradient;
    walls
        type            zeroGradient;
    defaultFaces
        type            empty;
alpha.water.org
internalField   uniform 0;
boundaryField
   oil
        type            fixedValue;
	value		uniform 0.0;
    water-1
        type            fixedValue;
	value		uniform 1.0;
     water-2
        type            fixedValue;
	value		uniform 1.0;
    outlet
        type            zeroGradient;
    walls
        type            zeroGradient;
    defaultFaces
        type            empty;
p_rgh
boundaryField
    oil
        type            zeroGradient;
    water-1
        type            zeroGradient;
    water-2
        type            zeroGradient;
    outlet
        type            fixedValue;
	value		uniform 0;
    walls
        type            zeroGradient;
U
boundaryField
   oil
        type            fixedValue;
        value           uniform (0.01386 0 0);
    water-1
        type            fixedValue;
        value           uniform (0 -0.011 0);
    water-2
        type            fixedValue;
    outlet
        type		zeroGradient;
    walls
        type            fixedValue;
        value           uniform (0 0 0);
taajaki is offline   Reply With Quote
Old   May 26, 2014, 15:22
Default contact angel in micro channel two phased flow
hi everyone
this is my third question in succession that none of them were answered however I hope to find the solution and post it here to help others...
I have a micro channel which you can see it here
I have a question about defining contact angel in this micro channel hopefully to see droplets in main channel.
1-Is it necessary to define contact angle to making droplets?(boundaries are correct?)
2-Is it suppose to define in main or lateral channels?
3-In which phase should I define it and how?
thank you
Old   August 16, 2014, 07:05
Retired Super Moderator
Bruno Santos
Greetings taajaki,
Sorry for the late reply, but I only now managed to have a somewhat better look at your questions.
For what I can figure out so far, the VOF approach in OpenFOAM does not yet contemplate micro-fluid behaviour or at least not very well. Here are some threads I've kept some track on regarding this issue, perhaps you can figure out something more from them:
Best regards,
Bruno
Old   October 23, 2014, 02:21
thanks for your attention Bruno
could you please take a look at this question: http://www.cfd-online.com/Forums/ope...o-channel.html
thanks alot
micro channel heat exchanger design serpil kaya Main CFD Forum 6 March 25, 2018 07:34
alternate droplet generation in double t channel using ansys fluent hariswch2 ANSYS 0 January 22, 2014 01:06
Doubts about turbulence in a micro channel shardiali Main CFD Forum 17 December 5, 2012 04:34
Using pimpleFoam to model pulsatile flow in a micro channel isaacp OpenFOAM Running, Solving & CFD 0 January 30, 2012 00:03
micro channel arashmarahel180 FLUENT 4 January 20, 2010 10:56
