kovamaniac |
May 27, 2014 05:11 |
k-omegaSST with nutUTabulatedWallFunction for incompressible RAS - OF v2.3.0
Hi.
As there is little (tending to 0) reference for this and as I would like to use it for my simulations, I would like to ask for any advice for my problem:
I am trying to do the channel395 case using k-omega SST turbulende model with the nutUTabulatedWallFunction.
I followed the precedure mentioned HERE and created the the table required.
I edited the 0/nut file to impement the wall function according to the description:
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
bottomWall
type nutTabulatedWallFunction;
uPlusTable uPlusWallFunctionData;
topWall
sides1_half0
type cyclic;
sides2_half0
type cyclic;
The first error I get is the following:
--> FOAM FATAL IO ERROR:
Essential entry 'value' missing
file: /home/user/OpenFOAM/user-2.3.0/run/channel395/0/nut.boundaryField.bottomWall from line 29 to line 31.
From function fvPatchField<Type>::fvPatchField(const fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict,const bool valueRequired)
in file /home/sergio/rpmbuild/BUILD/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvPatchField.C at line 148.
FOAM exiting
The above is very strange given the fact that description is clear. However, I move making this modification with a sample value 0 just to see if it going to run.
bottomWall
value uniform 0;
The error this time is the following:
--> FOAM FATAL ERROR:
Not implemented
From function Istream& ITstream::read(char*, std::streamsize)
in file db/IOstreams/Tstreams/ITstream.C at line 153.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::ITstream::read(char*, long) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#3 Foam::Istream& Foam::operator>><double>(Foam::Istream&, Foam::List<double>&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/simpleFoam"
#4 Foam::uniformInterpolationTable<double>::uniformInterpolationTable(Foam::IOobject const&, bool) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#5 Foam::incompressible::nutUTabulatedWallFunctionFvPatchScalarField::nutUTabulatedWallFunctionFvPatchScalarField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#6 Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::incompressible::nutUTabulatedWallFunctionFvPatchScalarField>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#7 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/simpleFoam"
#8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/simpleFoam"
#9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/simpleFoam"
#10 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/simpleFoam"
#11 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/simpleFoam"
#12 Foam::incompressible::autoCreateNut(Foam::word const&, Foam::fvMesh const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#13 Foam::incompressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&, Foam::word const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#14 Foam::incompressible::RASModel::adddictionaryConstructorToTable<Foam::incompressible::RASModels::kOmegaSST>::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#15 Foam::incompressible::RASModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#16
#17 __libc_start_main in "/lib64/libc.so.6"
#18
Aborted
Can anybody give me any idea?? Other wall functions work fine with my setup.
