August 25, 2019, 04:38 |
rhoCentralFoam (6) DOES NOT read fvOptions
Rep Power: 9 |
Dear Foamers -- looks like a bug:
rhoCentralFoam (6) DOES NOT read fvOptions upon solver execution. It does not read from /constant not from /system. Checked with rhoSimpleFoam -- no problem there. It is as if the file (fvOptions) is simply not there .. like file with this name does not exist. Thanks for looking into it. [Moderator note: Moved from the Bugs subforum to the CFD Solving forum.] Last edited by wyldckat; August 26, 2019 at 16:24. Reason: see "Moderator note:" |
August 25, 2019, 10:37 |
Rep Power: 14 |
rhoCentralFoam is not coded to use fvOptions, hence it is not read (and therefore not a bug).
Caelan |
August 26, 2019, 03:08 |
Rep Power: 9 |
Thanks! Suspected that. Would you happen to know a quick workaround to limit temperature or pressure in rhoCentralFoam? (sorry for posting in a 'bug thread')
August 26, 2019, 04:53 |
Carlo_P
Rep Power: 7 |
Hey,
you can limit pressure or temperature in fvSolution. Check this file: https://github.com/OpenFOAM/OpenFOAM...tem/fvSolution Instead of rhoMin and rhoMax you can use temperatureMin and temperatureMax and other variables. I think that the new version would like to have rhoMinFactor or something like this. |
August 26, 2019, 13:21 |
Rep Power: 9 |
Hi!
Appreciate that. This is for rhoCentralFoam and I wonder where to place something like minTemperature or minPressure in fvSolution and what these variables actually are. I can start looking into the code, but that is after I make sure nobody has a quick answer (not obvious from Google). Normally, I would limit the temperature in fvOptions which is not available under rhoCentralFoam. L 08/29/19 |
August 26, 2019, 16:34 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick notes:
January 25, 2021, 02:09 |
Matus Cvengros
Rep Power: 7 |
If that is the case, how come that official user guide advertises fvOptions?
https://www.openfoam.com/documentati...ntralFoam.html |
January 25, 2021, 03:07 |
Rep Power: 7 |
I had the same problem and updated the solver with just a few lines and recompiled it. Its all described in this post: Sudden Increase of residuals |
January 25, 2021, 03:32 |
#9 | |
Matus Cvengros
Rep Power: 7 |
January 25, 2021, 03:43 |
#10 |
Rep Power: 7 |
I am not sure what you mean with "additional statement". You have to include fvOptions in rhoCentralFoam.C, so you need the statement: #include "fvOptions.H. EEqnRCF is just a name I made up. RCF = rhoCentralFoam. This is just to use constrain and correct functionality. |
March 24, 2021, 06:55 |
#11 |
Rep Power: 7 |
Delete this comment please
Configuration of boundary conditions and fvOptions file | Raza Javed | OpenFOAM Running, Solving & CFD | 16 | May 3, 2019 16:35 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Parallel Error in ANSYS FLUENT 12 | zeusxx | FLUENT | 25 | July 17, 2015 04:40 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 09:46 |
