Flow around two tandem cylinders
Hello...
I am trying to simulate flow around two tandem circular cylinders. I am not able to replicate the results as reported in literature. The results are in well confirmation with the literature when spacing between the cylinders is increased. However, with the same case setup, I am unable to obtain results for less spacing (say spacing between cylinders is 2). The flow is having a Reynolds number of 100. Solver used is pisoFoam. Simulation is 2D and laminar. The schemes being used are linear schemes. Kindly suggest some measures. Thank You. |
Can you post comparison plot for your result here? |
Hey
Could you post some of your results? Maybe a line plot (velocity ...etc.) ... |
Thank you for your kind reply..
May I know which results should I post? I mean the velocity, pressure colour plots or cl, cd, cp plots? TD P { margin-bottom: 0cm; direction: ltr; color: rgb(0, 0, 0); }TD P.western { }TD P.cjk { }TD P.ctl { }P { margin-bottom: 0.21cm; direction: ltr; color: rgb(0, 0, 0); }P.western { }P.cjk { }P.ctl {* |
Hey
Could you share the mesh (an image) and maybe the contour plots of velocity & pressure? (For both simulations) |
What do you mean by this line..
