June 14, 2014, 11:41 |
NS-Equations an p-dimension
Olivia Nalen
Rep Power: 12 |
Hello dear foamers,
Does someone know, why is the dimension of pressure p [0 2 -2 ...]? That means, the pressure is actually not pressure, but pressure/density. And that's why should be the NS-equations defined not for pressure, but for pressure*density. Is this correct too? Kind regards, Olivia |
June 14, 2014, 11:55 |
these units are used only for incompressible N-S equations (as in this case you can just divide equations by density), if you take a look at ICs/BCs in compressible solvers examples, there units of pressure are Pa. |
June 14, 2014, 13:04 |
Olivia Nalen
Rep Power: 12 |
Hello Alexey,
thanks for an fast answer You said, I can divide equations by density, but I wonder, whether I had to? Or maybe I just can say that my density (air) = 1 and not worry about that? Kind regards, Olivia |
June 14, 2014, 14:13 |
Well,
Incompressible NS solvers in OpenFOAM are already implemented for equations that are divided by density (except multiphase solvers). If you'd like to implement your own solver, no you don't have to divide equations. If you'd like to use Pa for pressure, you have to correct units for other properties of the system, like viscosity (it'll become dynamic instead of kinematic, at this point you also need to correct turbulence model as for incompressible solvers turbulent viscosity is kinematic). These are the ones that come to mind, guess there can be other properties that are introduced through fvOptions mechanism. |
June 14, 2014, 17:19 |
Olivia Nalen
Rep Power: 12 |
Thanks a lot again,
Display Modes | |
Guide: Writing Equations in LaTeX on the CFD Online Forums | pete | Site Help, Feedback & Discussions | 27 | May 19, 2022 03:19 |
modelling Differential equations in a udf | RikardMNorén | Fluent UDF and Scheme Programming | 2 | October 1, 2013 03:36 |
Riemann invariants of adjoint equations of shallow water equations | zqb0929 | Main CFD Forum | 0 | March 15, 2012 00:54 |
CFD governing equations | m.gos | Main CFD Forum | 0 | April 30, 2011 14:21 |
solving only turbulence equations | afroz_javed | OpenFOAM | 1 | January 20, 2011 05:25 |
