which file should I modified in order to improve the explicit Euler method?
Old   June 16, 2014, 18:15
Default which file should I modified in order to improve the explicit Euler method?
chun is on a distinguished road
Dear FOAMers,
I studied a paper which is applying RK4 and ARK3 to improve the explicit Euler method.
The paper provide the implementation, but I don't know which file should I modify to make that happened.
p.s. since the paper is too big to upload, I just give the information below.
<On the implementation of low-dissipative Runge–Kutta projection
methods for time dependent flows using OpenFOAM> by V. Vuorinen, J.-P. Keskinen, C. Duwig, B.J. Boersma.
You can find the paper in http://www.sciencedirect.com/science...45793014000334
Could anyone give me a hint? Your help is greatly appreciated.
Chun
chun is offline   Reply With Quote
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
which file should I modified in order to improve the explicit Euler method? chun OpenFOAM 1 June 16, 2014 18:20
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
