Having problem in reaching steady temperature with flux.
Old   June 25, 2014, 15:01
Default Having problem in reaching steady temperature with flux.
Gabriel de PInho RImoli
Grimoli is on a distinguished road
Hello everybody.
I have a question
I'm using chtMultiRegionFoam but I cant reach a steady temperature when I impose flux in the base.
What're the conditions to reach a steady temperature ??
Ps: Im using a modified case of the tutorials,i just changed the geometry and the boundary conditions of the case.
Thats how Im imposing the flux :
boundaryField
type zeroGradient;
value uniform 294.05;
"heater_to_.*"
type compressible::turbulentTemperatureCoupledBaffleMix ed;
neighbourFieldName T;
K solidThermo;
KName none;
minZ
type fixedGradient;
gradient uniform 7.53;
Maybe should I impose the flux on a different way??I know about the groovy BC but im getting trouble in installing it.The temperature in my case keeps raising and the case doesnt get in a steady state.
Can someone help me??
Grimoli is offline   Reply With Quote
Old   June 25, 2014, 17:21
help me pleae
Old   June 26, 2014, 02:43
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
With your boundary conditions you have a system that has a net positive heat flux. You need to set one boundary at a fixed temperature. For steady state the net heat flux must be zero.
Regards,
Tom
tomf is offline   Reply With Quote
TEMPERATURE LIMITED problem emanuele FLUENT 9 June 15, 2018 10:45
DPM problem - wrong particle temperature Johannes FLUENT 1 December 1, 2014 12:48
Temperature and heat flux wall boundary condition L. Hamid Main CFD Forum 3 February 22, 2014 21:10
Defining of initial temperature of certain body in unsteady heat transfer problem toodrunktorun FLUENT 1 September 5, 2013 09:34
same static and total temperature problem preetam69 FLUENT 1 August 15, 2013 17:17
