patchFlowRateInjection
Like Tree6Likes
  • 5 Post By ecbmxer
  • 1 Post By atul1018
Old   July 2, 2014, 10:51
Default patchFlowRateInjection
Clint Bedick
ecbmxer is on a distinguished road
Have any of you guys used the patchFlowRateInjection injection model?
There is one required input that I'm unsure of. You must specify a "concentration", which the source file describes as "concentration profile of particle volume to carrier volume", and is non-dimensional. But I also must specify a true particle concentration, in #particles/m3, and also a total mass to inject. In addition I have a constant particle density and set a size distribution.
How can all of these values be specified at the same time? Ideally, I would like to just say, I want to inject n particles from t0 to t1.
I'd appreciate any additional info on this injection model. I'm in the process of experimenting with these parameters.
Thanks,
-Clint
ecbmxer is offline   Reply With Quote
Old   July 5, 2014, 16:54
Clint Bedick
I just wanted to respond back to this in case others are searching for info related to this boundary condition.
Basically, you only need to specify (2) parameters: concentration and parcelConcentration. If you specify parcelBasis as "number", the totalMass value is not used at all. For my simulation, I want each parcel to only be made up of a single particle. So I set nParticles to 1 and just played around with values for concentration and parcelConcentration until I introduced the number of parcels I wanted. If you want to be exact about the parcel injection rate, you will need to specify a fixed particle size and number of particles per parcel so you can compute the ratio of the volume flow rate of particles to volume flow rate of gas, and then set the concentration as your actual number of parcels per volume of gas.
Either way, this boundary condition appears to work well to inject particles at the gas velocity, especially when you have a variable inlet velocity (groovyBC, etc) that makes it tough to directly specify the initial particle velocity for a patch injection.
Old   October 18, 2016, 02:22
Alaska1964
Alaska1964 is on a distinguished road
I am simulating gas phase velocity as time dependent and trying to apply the same velocity table for particle. I am using patch injection and U0 for particles in patch injection is defined as const. Any idea how I can give a time dependent table for particle velocity?
thanks in andvance for your time,
Alaska1964 is offline   Reply With Quote
Old   May 4, 2021, 11:29
Smile
UOCFD
uosilos is on a distinguished road
Originally Posted by Alaska1964 View Post
any hint??
uosilos is offline   Reply With Quote
Old   May 21, 2021, 09:21
atul1018 is on a distinguished road
Hey ecbmxer
its an old post but very relevant as there are not so much written about patchFlowRateInjecton. I wanted to know what do you mean by when you wrote "played around with values for concentration and parcelConcentration until I introduced the number of parcels I wanted". shouldn't they have some definite meaning and according to that they must be calculated.
the keyword concentration is described as "Concentration profile of particle volume to carrier volume" in source code. Here I wonder what they mean? it seems like its not the voulemtric concentration of particle (particle vol discharge/fluid volumetric discharge) and it should be constant. what this profile term is?
Best Regards
Atul
Akimlav likes this.
atul1018 is offline   Reply With Quote
