Wall heat transfer
I would like to solve heat transfer from an air flow through a metal wall to surrounding air without modelling the solid wall thickenss (separate mesh). The BC would be set as: Internal wall temperature is calculated Internal heat transfer coefficient is calculated Wall thickens and conductivity are assigned External surrounding temperature is assigned Is it possible to use for this problem BC externalWallHeatFlux or is there some other BC for this propose? Is there some tutorial solving this problem? Thanks |
Hello Altan,
The externalWallHeatFlux fits perfectly to your description. Code:
wall Only supply \c h and \c Ta, or \c q in the dictionary |
Wall heat transfer
Thanks for the response. I am now testing this BC with rhoSimpleFoam.
