rhoPimpleFoam k-omega sst crashes channel flow |
July 14, 2014, 10:05 |
Rep Power: 12 |
Hi guys,
I am trying to simulate a channelFlow at Re=5000 with rhoPimpleFoam. Problem is my simulation crashes immediately: Code:
Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 10 corrector loops Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } AMI: Creating addressing and weights between 30912 source faces and 30912 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 1, 1 Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RASModel Selecting RAS turbulence model kOmegaSST #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #6 Foam::compressible::RASModels::kOmegaSST::F2() const at ??:? #7 Foam::compressible::RASModels::kOmegaSST::F23() const at ??:? #8 Foam::compressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) at ??:? ............... Where is the problem? Thanks in advance! Last edited by hxaxtma; July 14, 2014 at 11:25. |
July 15, 2014, 05:04 |
Albrecht vBoetticher
Rep Power: 16 |
you devide by zero, and I guess your initial zero pressure field is the reason.
July 15, 2014, 05:18 |
Rep Power: 12 |
Display Modes | |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
flow depth in channel | mahdi1 | FLOW-3D | 5 | May 30, 2013 05:28 |
gas flow out of a C-D channel | ljp | FLUENT | 0 | March 7, 2011 14:32 |
Flow within a thin channel | al0Vera | FLUENT | 0 | June 15, 2009 10:20 |
compressible channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 17, 1998 17:23 |
