August 11, 2014, 16:07 |
Boiling Flow in Minichannels
Parisa
Rep Power: 13 |
Hello OpenFoam experts,
I would like to simulate flow boiling in a channel flow, say minichannels. Is there any available solver in OpenFOAM to model that? For sure, I would like to use VOF. I really appreciate your kind advice and help. Cheers, Parisa |
August 11, 2014, 17:16 |
Parisa
Rep Power: 13 |
I am really anticipating your helps, guys,
Thanks a lot, Parisa |
August 12, 2014, 07:02 |
Parisa
Rep Power: 13 |
Nobody?
August 12, 2014, 08:56 |
Rep Power: 12 |
What kind of medium you want to simulate ? Compressible or incompressible ?
I would suggest you this scroll down to Multiphase section. Maybe you will find something interesting. cheers seav
Cheers, seav "OpenFOAM is like a strict teacher, won't let you through until all is correct or better say until one has understood the sensitivities of a problem." -jaswi |
August 12, 2014, 10:50 |
Parisa
Rep Power: 13 |
Thanks for your response,
I would like to simulate incomprehensible using VOF. I think twoPhaseEulerFoam is OK to start with. However, I would like to know about the limitations of this solver. Or any suggestion? |
August 12, 2014, 11:32 |
Rep Power: 12 |
I have never used this solver. Only tip I can give you is to explore ~/OpenFOAM-version/applications/solvers/multiphase/twoPhaseEulerFoam/ *.H files, *.C files and all others.
Maybe you will find something interesting. seav
August 12, 2014, 12:16 |
Parisa
Rep Power: 13 |
Thanks a lot,
Yes, I am working on them. Cheers, Parisa |
August 12, 2014, 12:52 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
A word of caution: there have been a few threads on the OpenFOAM sub-forums discussing whether it was possible to simulate VOF in a micro scale. So far I have not seen any positive feedback on this being possible. The closest I've seen has been the possibility to observe the capillary effect, as demonstrated by the tutorial "multiphase/interFoam/laminar/capillaryRise". Best regards, Bruno
August 12, 2014, 12:56 |
#9 |
Parisa
Rep Power: 13 |
Thanks wyldckat,
However, my case is not in micro scale. Suppose that I am simulationg boiling flow in macro scale. Do you know any valid solver? I would like to use VOF. What do you think about twoPhaseEulerFoam? Thanks |
August 12, 2014, 13:23 |
#10 | |
Bruno Santos
Rep Power: 128 |
I assumed the worst case scenario, since "minichannels" would likely be in the millimetre scale, which could be close enough to micro scale. Unfortunately I'm not familiar with any solver in OpenFOAM which provides the ability to solve boiling fluid flow. From what I can see on the page Seav suggested, none of the existing solvers in OpenFOAM 2.3.0 will be able to simulate this. A quick search with Google about "OpenFOAM boiling" lead me to this thread: http://www.cfd-online.com/Forums/ope...hangefoam.html edit: I vaguely remembered something named "evap" in OpenFOAM... oh, I have a solver named evapVOFHardt built in my environment for OpenFOAM 2.3. Looks like I handled a quick port of it for OpenFOAM and provided it here: https://github.com/wyldckat/evapVOFHardt The original source code and documentation is provided here: http://www.ttd.tu-darmstadt.de/forsc...vofhard.en.jsp Last edited by wyldckat; August 12, 2014 at 13:26. Reason: see "edit:" |
August 12, 2014, 16:25 |
#11 |
Wouter van der Meer
Rep Power: 17 |
Hello Parisa_Khiabani
this thesis is about boiling as far as I can tell Code:
Development and validation of a two-phase CFD model using OpenFOAM Alberto Ghione Wouter |
August 12, 2014, 17:34 |
#12 |
Parisa
Rep Power: 13 |
Dear wouter,
Thanks for your kind help. Parisa |
August 13, 2014, 06:29 |
#13 |
Joachim Herb
Rep Power: 21 |
Also have a look at this thesis:
https://mediatum.ub.tum.de/node?id=1172612 |
August 13, 2014, 10:32 |
#14 |
Markus Rehm
Rep Power: 17 |
you could also check this: http://www.cfd-online.com/Forums/ope...se-change.html http://openfoamwiki.net/index.php/Co...haseChangeFoam Please report your experience. Markus |
August 28, 2014, 02:27 |
#15 |
Mohammad Bahreini
Rep Power: 13 |
If you want use VOF method for simulation , you should make own solver and implement mass transfer model foe phase change
Best |
March 24, 2015, 19:31 |
#16 |
james wilson
Rep Power: 11 |
check this post out: http://www.cfd-online.com/Forums/mai...tml#post538055
bubble diameter definition in multi phase flow boiling simulation FLUENT | Abishek | FLUENT | 13 | July 1, 2019 12:12 |
Non-steady flow simplified for use in Vissim | steamerandy | Main CFD Forum | 0 | October 31, 2011 21:08 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
