hchen |
August 20, 2014 10:03 |
Object registry problem
I want to define a boundary condition for a subset mesh motion.
I collect the boundary points by:
pointVectorField& PointDisplacement = const_cast<pointVectorField&>
subset1Mesh_.subMesh().objectRegistry::lookupObject<pointVectorField>
"pointDisplacement"
pointField & subset1Boundary = refCast<pointField>(PointDisplacement.boundaryField()[patchIndex]);
where subset1Mesh is the subset-Mesh region that I want to move.
when I run the case, the error shows that:
--> FOAM FATAL ERROR:
request for pointVectorField pointDisplacement from object Registry motionSubset failed
available objects of type pointVectorField are
0
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/hchen/foam/foam-extend-3.1/src/foam/lnInclude/objectRegistryTemplates.C at line 139.
FOAM aborting
I suspect that is due to something like the hierarchy of the object registry.It can not find the file pointDisplacement in the sub-directory motionSubset under the main directory 0.There might be something wrong with subset1Mesh_.subMesh()....
Anybody could help me? Thanks very much!
Best regards
Hao
