fatal error
Old   August 25, 2014, 11:09
Default fatal error
zohreh imani nejad
imani is on a distinguished road
hi formers
who know what is this error?
--> FOAM FATAL ERROR:
updateCoeffs(const scalarField& snGradp) MUST be called before updateCoeffs() or evaluate() to set the boundary gradient.
From function fixedFluxPressureFvPatchScalarField::updateCoeffs( )
in file fields/fvPatchFields/derived/fixedFluxPressure/fixedFluxPressureFvPatchScalarField.C at line 151.
FOAM exiting
imani is offline   Reply With Quote
Old   August 30, 2014, 10:50
Retired Super Moderator
Bruno Santos
Greetings imani,
I probably have already seen this error before, but from only the very brief information you've given, I cannot remember what was the problem that I saw back then... possibly over 1 year ago.
Please provide more detailed information, as explained here: http://www.cfd-online.com/Forums/ope...-get-help.html
Best regards,
Bruno
Old   August 30, 2014, 11:11
zohreh imani nejad
hi
i want ti run a case with openFoam 230
in p_rgh i use fixedFluxPressure boundary condition
but i have that error
in of211 we should use buoyantPresssure
but in of230 we should use FixedFluxPressure
but in my program it is wrong
Old   August 30, 2014, 11:56
Bruno Santos
Unfortunately that is still not enough information.
Since you did not provide enough information, I'm only able to suggest that you compare the same tutorial case from each OpenFOAM version, to try and see if there are any more details that need to be changed.
For example, you could use the following command for comparing the two folders:
diff -Nur case_211 case_230 > differences.txt
This will compare all files within the folder "case_211" versus the folder "case_230" and will place the differences inside the file "differences.txt".
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
