simpleFoam: switching flow direction with kOmegaSST RAS Model
Old   September 2, 2014, 15:25
Default simpleFoam: switching flow direction with kOmegaSST RAS Model
Jason G.
JasonG is on a distinguished road
I have been looking at pressure drops for internally bounded, steady-state, incompressible fluid flow cases with the simpleFoam solver. Typically, I specify a velocity at the entrance to the fluid domain and a reference pressure of 0 at the exit of the fluid domain.
A new case I am working on requires me to specify a velocity at the exit and a reference pressure at the entrance. I have been able to successfully do this with laminar assumptions, but as soon as I attempt to switch to the kOmegaSST turbulence solver I run into convergence issues. It appears the kinetic turbulence values become discontinuous near the entrance.
Any help and/or recommendations are greatly appreciated. Below are the current BC's I am implementing:
"intialConditions"
flowVelocity         (0 0 165.760612715333);
pressure             0;
turbulentKE          194.091657099187;
turbulentOmega       1731.03910939215;
kinematicvis         nu [ 0 2 -1 0 0 0 0 ] 0.0398447454916618;   // in^2/s
density             0.00007839;           //  Value of the density(sslug/in^3) pstatic = lbf/in^2
//RAS PROPERTIES
RAS_MODEL         kOmegaSST; //kOmegaSST;    //laminar;
turb_on_off         on;    //on
#inputMode           merge
"p"
#include        "initialConditions"
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $pressure;
boundaryField
    outlet_1
        type            inletOutlet;
        inletValue      $internalField;
        value           $internalField;
    inlet_1
        type            fixedValue;
    boundary
        type            zeroGradient;
    symmetry
        type        symmetryPlane;
"u"
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    outlet_1
        type            outletInlet;
        outletValue     $flowVelocity;
        value           $flowVelocity;
    inlet_1
        type            outletInlet;
        outletValue     $internalField;
    boundary
        type            fixedValue;
    symmetry
        type        symmetryPlane;
"k"
internalField   uniform $turbulentKE;
boundaryField
    outlet_1
       type  fixedValue;
    inlet_1
        type            outletInlet;
    boundary
        type            kqRWallFunction;
    symmetry
        type        symmetryPlane;
"nut"
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet_1
        type            calculated;
        value           uniform 0;
    outlet_1
        type            calculated;
        value           uniform 0;
     boundary
        type            nutLowReWallFunction;
        value           uniform 0;
    symmetry
        type        symmetryPlane;
"omega"
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform $turbulentOmega;
boundaryField
    outlet_1
       type  fixedValue;
    inlet_1
        type            outletInlet;
    boundary
        type            omegaWallFunction;
    symmetry
        type        symmetryPlane;
JasonG is offline   Reply With Quote
Old   September 25, 2014, 07:26
Joachim Herb
jherb is on a distinguished road
You might try the fixedMean boundary condition for the velocity, k and omega at the outlet (assuming the the specified flow is going "outwards").
Then you do not enforce a constant value over the whole outlet but just the (area averaged) mean for the three quantities. So the turbulent block profile within your flow domain is not destroyed at the outlet.
jherb is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model us FLUENT 5 April 5, 2011 02:29
Ho to model the flow in a Regenerator alexandrepereira OpenFOAM Running, Solving & CFD 2 August 25, 2010 17:35
