simpleFoam & pimpleDyMFoam jump on fields
Old   September 17, 2014, 23:03
Default simpleFoam & pimpleDyMFoam jump on fields
M. C.
student666 is on a distinguished road
Hi all,
I ran the same case with different solvers, it's similar to the 2Dmixervessel tutorial, but 3D.
To obtain the mesh, I merged stator and rotor cellZones and defined AMI patches at interface.
I ran once using pimpleDyMFoam and I had pressure and velocity field with no jump across AMI interfaces.
If I run the case using simpleFoam with fvOptions, I see a jump on both fields across the surface. Why? Is there a way to smooth this?
Here's a picture of the simpleFoam case.
https://www.dropbox.com/s/r0lupkk4buqkwof/p.png?dl=0
student666 is offline   Reply With Quote
Old   September 17, 2014, 23:07
M. C.
here's the log file of the simpleFoam case
https://www.dropbox.com/s/5dx0hgl9kl...n.logfile?dl=0
Old   September 18, 2014, 14:31
M. C.
Problem solved, when you use simpleFoam with fvOptions you have not to forget the not rotating patches into dictionary.
That's the reason of the jump.
Hope this help.
From simpleFoam to pimpleDyMFoam gregjunqua OpenFOAM Running, Solving & CFD 0 May 6, 2014 20:48
a reconstructPar issue immortality OpenFOAM Post-Processing 8 June 16, 2013 11:25
an odd(at least for me!) reconstructPar error on a field immortality OpenFOAM Running, Solving & CFD 3 June 3, 2013 22:36
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
write nut fields in simpleFoam maurice OpenFOAM Running, Solving & CFD 5 March 23, 2009 01:57
