September 27, 2014, 15:47 |
velocity inlet definition
Ali reza
Rep Power: 12 |
hello everyone
I have simulated fluid flow in a pipe. velocity inlet was defined at the inlet of the pipe . I want to set the velocity profile the same as which has been shown in the picture. this function does not have an specific definition so I think I have to define it by list of digits which is consist of velocities and times. I have no idea about defining these digits as a velocity inlet in Openfoam, please help me to solve the problem. thanks |
September 28, 2014, 06:28 |
Ali reza
Rep Power: 12 |
should I define it in this way?
OpenFOAM table file uniformValue tableFile; tableFileCoeffs { fileName "$FOAM_CASE/myDataFile" outOfBounds clamp; } |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 17:24 |
How to apply an outlet velocity profile to another inlet? | siw | FLUENT | 4 | April 10, 2013 11:19 |
Velocity Inlet BC -- Flow Reversal | salihovic | FLUENT | 0 | May 8, 2011 05:45 |
User Defined Profiles, Swirl, Velocity Inlet | saurus | FLUENT | 0 | January 26, 2011 15:35 |
UDF paraboloid velocity inlet | Ronak Shah | FLUENT | 0 | June 4, 2003 09:44 |
