Problem with cyclicAMI and simpleFoam
Like Tree1Likes
  • 1 Post By taxalian
Old   September 25, 2014, 08:29
Default Problem with cyclicAMI and simpleFoam
Matej Milavec
Bluewater is on a distinguished road
Dear Foamers,
i am learning how to calculate rotating machines in OpenFOAM. I have a problem with the cyclic boundary condition in the rotor domain. Attached a picture that shows the cross section at the midle of the rotor domain of pressure contour with very high or low (unrealistic) values close to the cycly BC.
Basically I have done the following steps.
1)The mesh I converted to OpenFoam using "Fluent3DMeshToFoam".
2)Then I defined for the cyclic boundary conditions "cyclicAMI" in the boundary file as below
p1-rotor
type cyclicAMI;
inGroups 1(cyclicAMI);
matchTolerance 0.0001;
transform rotational;
neighbourPatch p2_rotor;
rotationAxis (0 0 1);
rotationCentre (0 0 0);
nFaces 5871;
startFace 6734366;
p2_rotor
type cyclicAMI;
neighbourPatch p1_rotor;
nFaces 5871;
startFace 6751983;
3) In the fvOptions the corresponding angular velocity on rotor domain.
MRF1
type MRFSource;
active true;
selectionMode cellZone;
cellZone rotor;
MRFSourceCoeffs
origin (0 0 0);
axis (0 0 1);
omega 77.5;
The residuals after 4000 iterations are for pressure just below 10-e3, velocities below 10-e4 and k and omega below 10-e5.
Does anyone knows why my strange results chose to the cyclicAMI boundary condition?
Thanks in advance,
Mat
Last edited by Bluewater; September 30, 2014 at 01:06. Reason: I uploaded a .png file but something went wrong
Bluewater is offline   Reply With Quote
Old   September 26, 2014, 16:53
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
It seems that you are trying to use OF MRF module, as you are using the fvOptions dict. My suggestion would be to try setting your cyclicAMI patches as non-rotating ones. This might improve strange behaviour near the cyclicAMI boundaries.
Originally Posted by Bluewater View Post
Dear Foamers,
p1-rotor
type cyclicAMI;
nFaces 5871;
startFace 6734366;
p2_rotor
type cyclicAMI;
nFaces 5871;
startFace 6751983;
MRF1
type MRFSource;
active true;
cellZone rotor;
MRFSourceCoeffs
origin (0 0 0);
axis (0 0 1);
omega 77.5;
Thanks in advance,
Mat
Bluewater likes this.
taxalian is offline   Reply With Quote
Old   September 29, 2014, 07:02
Matej Milavec
Hi Taxalian,
in fact the cyclic boundary conditions have to rotate with the domain defined as rotational domain. The model consist of one blade (see picture posted in my first post) that spans 72 degrees (so the real whole model has 5 blades). As you suggested I have defined in "fvOptions" file at "noRotatingPatches()" field the two periodic patches (they are defined in "boundary" file as "patches" but with a "createPatchDict" I tranform them to "cyclicAMI", correct me if this is a wrong procedure, because I do not know how to address directly "cyclicAMI" in "noRotatingPatches()").
MRF1
    type            MRFSource;
    active          true;
    cellZone        fluid_rotor;
    MRFSourceCoeffs
        nonRotatingPatches (p1-fluid_rotor p2-fluid_rotor);
        origin      (0 0 0);
        axis        (0 0 1);
        omega       77.5;
The "createPatchDict" looks:
patches
        name            p1_rotor;
        patchInfo
            type            cyclicAMI;
        constructFrom patches;
        patches (p1-fluid_rotor);
        name            p2_rotor;
        patchInfo
            type            cyclicAMI;
        patches (p2-fluid_rotor);
I do not understand why for example under 0/* I have to address the cyclicAMI with the names that I use in "constructFrom patches;" of "createPatchDicht", since from the moment I have redefined them as "cyclicAMI" it has already a new name (i. e. in my case p1_rotor and p2_rotor).
If I look at the results now as expected the two cyclicAMI do not rotate, they behave as walls (velocity is 0.) I would expect an easy way to get the cyclicAMI rotate in the proper way), there are any idea? I am doing something wrong?
Last edited by Bluewater; September 29, 2014 at 10:46. Reason: to clarify better content
Old   October 1, 2014, 03:54
Matej Milavec
after some trials I do not see how to get that the periodic bondary conditions (defined as "cyclicAMI") in the rotational domain do what is expected, look the two pictures attached, where it is clear that they rotate in the contrary direction. This clarifies also the strange pressure contours closed to the periodic b.c. I attached in my first post. Does anyone in this forum work with this kind of problems, or "cyclicAMI" inside a "cellZone" that rotates and defined as such in "fvOptions" with "MRFSource"?
cyclicami, frozen rotor, simplefoam
cyclicAMI + simpleFoam crashes in parallel jmf OpenFOAM Running, Solving & CFD 6 June 28, 2017 15:30
Law of the wall: k-omega vs. Spalart-Allmaras (simpleFoam) MrFourier OpenFOAM Running, Solving & CFD 17 June 17, 2014 04:08
CyclicAMI with translation and pressure jump across inlet and outlet santoshgoku OpenFOAM Running, Solving & CFD 5 January 15, 2014 11:37
