BC on flow around a square?
Old   September 29, 2014, 13:34
Default BC on flow around a square? [icoFoam]
Wizze is on a distinguished road
Hey everyone
I am trying to simulate a flow around a square using icoFoam. I can't figure out what my boundary conditions are supposed to be. Any suggestions on how i should do it? I have tried to depict my case in the attached picture. I have created my mesh by using ICEM.
I am getting the "Floating point exception (core dumped)" error.
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    TOP
        type            slip;
    OUTLET
        type            fixedValue;
	value		uniform 0;
    BOTTOM
        type            slip;
    INLET
        type            zeroGradient;
    WALL
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    TOP
        type            slip;
    OUTLET
        type            zeroGradient;
    BOTTOM
        type            slip;
    INLET
        type            fixedValue;
	value		uniform (10 0 0);
    WALL
        type            fixedValue;
	value		uniform (0 0 0);
Last edited by Wizze; September 30, 2014 at 10:07. Reason: Problem changed from piso to icoFoam
Wizze is offline   Reply With Quote
Old   September 30, 2014, 11:15
mohsen cheraghi
mohsen cheraghi is on a distinguished road
Originally Posted by Wizze View Post
Hey everyone
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    TOP
        type            slip;
    OUTLET
        type            fixedValue;
	value		uniform 0;
    BOTTOM
        type            slip;
    INLET
        type            zeroGradient;
    WALL
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    TOP
        type            slip;
    OUTLET
        type            zeroGradient;
    BOTTOM
        type            slip;
    INLET
        type            fixedValue;
    WALL
        type            fixedValue;
Hi, you shoud change the BC of pressure on the top and bottom to zeroGradient.
mohsen cheraghi is offline   Reply With Quote
Old   September 30, 2014, 11:20
How come? I want the top and bottom to not have the non-slip condition (so the square I am investigating doesn't get affected by this) , hence I have slip as a BC. Does slip only work for velocity since you are only suggesting me to change the pressure BC?
Old   September 30, 2014, 11:25
mohsen cheraghi
I think slip condition for v and zeroGradient for P is OK.
Old   September 30, 2014, 11:28
Could you please explain in detail? :-)
Old   September 30, 2014, 11:32
mohsen cheraghi
Slip BC is defined for velocity. it considers zero gradient for tangential component and zero value for normal component. But, for pressure as a scalar field, you should put zeroGradient.
Old   September 30, 2014, 11:35
Still not working. I suspect something is wrong in my fvschemses and fvsolution files. I just used what I found in the icoFoam cavity tutorial. Any suggestions?
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Simulation flow past square cylinder 3d Gabba82 FLUENT 0 November 22, 2009 07:05
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Slug flow in square channel PaulC FLUENT 0 December 5, 2005 02:03
