What are causes of difference between solution of similar cases?
Old   November 20, 2020, 07:07
Default What are causes of difference between solution of similar cases?
mohsali
mohsali is on a distinguished road
Hi
im newbie in openFOAM and practicing tutorials of the user guide.in the "Breaking of a dam" tutorial, the results of my solution have differences from reported results in the user guide.
i did the tutorial step by step and exactly same as the user guide.
what are the causes of these small differences in the results?
thnx
mohsali is offline   Reply With Quote
Old   November 20, 2020, 07:42
anonymous
simrego is on a distinguished road
Hi!
If they case is "untouched", so you just download and run, it is possible that the results in the user guide made with slightly different setup, or simply something is changed in the code, and it can slightly affect the solution. Hopefully it became more robust and accurate.
For example sometimes the schemes are changing in the tutorials over time, and I think they don't update the figures in the user guide after every release.
So for really small differences I shouldn't spend too much time on it. If there are BIG differences, then there should be something wrong... Also this is modelling, so your results will be always "wrong", but hopefully they will be less and less wrong...
simrego is offline   Reply With Quote
breaking of a dam, difference, solution, tutorial
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Initial solution from potentialFoam (or similar) Gerry Kan OpenFOAM Running, Solving & CFD 4 February 20, 2020 10:58
How to compare temperature difference at same position between two cases? Dorasemon FLUENT 3 December 19, 2018 05:54
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
