fvsolutions relaxation factor
Like Tree1Likes
  • 1 Post By RodriguezFatz
Old   October 8, 2014, 16:22
Default fvsolutions relaxation factor
Altan
alyucel is on a distinguished road
hi,
while I was searching tutorials I found something
in some fv solutions
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
        omega           0.7;
or
relaxationFactors
    p               0.3;
    U               0.7;
    k               0.7;
    epsilon         0.7;
    R               0.7;
    nuTilda         0.7;
what is the differ p in field or not
also some one
relaxationFactors
    fields
    equations
        "U.*"           1;
        "k.*"           1;
        "epsilon.*"     1;
what is "U.*"
alyucel is offline   Reply With Quote
Old   October 8, 2014, 16:38
Altan
also
in simpleFoam>>pipeCyclic tutorial
PIMPLE
    nOuterCorrectors 4;
    nCorrectors     1;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
SIMPLE
    residualControl
        p               1e-2;
        U               1e-3;
        "(k|epsilon)"   1e-3;
is it normal simple and pimğle in same fvsolution
Old   October 9, 2014, 03:30
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hey alyucel, I am not sure about your first question. I am wondering the same thing and never found a good explanation for the syntax.
But to your second post: fvSolution contains info for the solver. The solver "simple" will use all information after the keyword "SIMPLE { ... }". It will just not consider the stuff after "PIMPLE { ...}". So if you have both in one file, you will be able to start your case with both solvers pimple and simple.
wanggl likes this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Under relaxation factor for external coupling dhxlxz CFX 10 August 11, 2015 20:52
relaxation factor for PISO algorithm sasanghomi OpenFOAM Running, Solving & CFD 1 February 2, 2013 05:51
under relaxation factor and the steady state jing113cn FLUENT 0 November 2, 2009 12:13
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 14:37
Relaxation factor Moon Siemens 1 June 13, 2003 11:13
