Partial slip Johnson-Jackson wall boundary condition OF 2.3.0
Old   October 23, 2014, 14:28
Default Partial slip Johnson-Jackson wall boundary condition OF 2.3.0
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Hello everyone
I am also working with fluidizedBed/RAS (twoPhaseEuler) model. I am using 2.3.0. In my simulation I want to apply partially slip Johanson Jackson boundary condition. My theta.Particles and U.particles boundary conditions (in 0 folder) are as follows
for theeta
walls
type zeroGradient;
for U.particles
walls
type fixedValue;
value uniform (0 0 0);
does it mean no slip boundary condition ? If it is so, how can I define partially slip boundary condition. Also where to define "Specularity coefficient"
mwaqas is offline   Reply With Quote
Old   October 28, 2014, 04:34
Ramon
RjwV is on a distinguished road
This is indeed no-slip what you have currently. If you want partial slip then you will either have to implement it yourself in v. 2.3.0 or you can download the development version 2.3.x from the repositories.
In 2.3.x Johnson and Jackson B.C. has been built in already (I am currently testing it).
You can use the following to set your Johnson and Jackson B.C. in U.particles:
wall
    type JohnsonJacksonParticleSlip;
    specularityCoefficient 0.50; // Or whatever value you want..
    value $internalField;
and in Theta.particles:
wall
    type JohnsonJacksonParticleTheta;
    restitutionCoefficient 0.90;  // Or whatever value you want..
Hope this helps.
As a side-not: I have been playing around a bit with this B.C. and for now it seems the simulations are crashing. My alpha.particle seems to exceed the maximum packing value which causes my radial distribution function to go haywire. If you notice anything similar please let me/us know.
Kind regards,
Ramon
RjwV is offline   Reply With Quote
Old   October 29, 2014, 14:58
Muhammad Waqas
Hello Ramon
Thank you very much. Your comment is very useful. Within a couple of days I will update to V2.3.x, then I will apply partially slip boundary condition. After that I will update my simulation result here.
Regards
mwaqas
Old   December 4, 2014, 17:10
Muhammad Waqas
Hello Ramon
I have updated OpenFOAM-2.3.0 to OpenFOAM-2.3.x. In boundary field, I cant find JohansonJacksonParticalSlip boundary condition. Here is the path where I am looking for it.
home/waqas/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/fields/fvPatchFields/derived
Regards
mwaqas
Old   December 4, 2014, 17:15
Ramon
Mwaqas, I suggest you look in applications, solver, multiphase, twophaseeulerfoam. It should be there somewhere.
KR.
Ramon
Old   December 4, 2014, 18:44
Muhammad Waqas
Hello Ramon
Thank you for your quick response. I found the boundary condition .
Are you still facing problem of maximum packing limit or your case is working fine. I am running some cases, after completing simulation, I will post my result.
Regards
mwaqas
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 04:13
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Slip boundary condition what is inside normunds OpenFOAM Running, Solving & CFD 2 June 4, 2007 06:45
wall slip boundary condition Federico FLUENT 0 February 6, 2007 03:12
