VOF Transient Error
Old   November 13, 2014, 19:38
Exclamation VOF Transient Error
RKanesan Ramasamy
rkanesan is on a distinguished road
Hi..
I'm tried to run VOF simulation in transient mode with the simulation decomposed in 8 parts. After a day of the simulation, simulation terminated with error message: (copied below)
Guys please help me to solve this error.
Courant Number mean: 8.5843e-05 max: 0.92284
Interface Courant Number mean: 5.5281e-09 max: 0.00013365
#0 #0 #0 [6] #0 #0 #0 ##0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&)Foam::error:rintStac k(Foam::Ostream&)Foam::error:rintStack(Foam::Ost ream&)Foam::error:rintStack(Foam::Ostream&)Foam: :error:rintStack(Foam::Ostream&)0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&) in in in in in in in in "/usr/local/OpenFOAM/OpenFOAM-"/usr/local/OpenFOAM/OpenFOAM-1.7."/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/l"/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOp1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so""/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/0/lib/linux64GccDPOpt/libOpenFOAM.so""/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.inux64GccDPOpt/libOpenFOAM.so"
[3] #1 so"
[1] #1 t/libOpenFOAM.so"
[7] #1 "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[6] #1
libOpenFOAM.so"
[0] #1
[2] #1 Foam::sigFpe::sigFpeHandler(int)Foam::sigFpe::sigF peHandler(int)Foam::sigFpe::sigFpeHandler(int)Foam ::sigFpe::sigFpeHandler(int)Foam::sigFpe::sigFpeHa ndler(int)Foam::sigFpe::sigFpeHandler(int)[5] #1 "/Foam::sigFpe::sigFpeHandler(int)usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[4] #1 Foam::sigFpe::sigFpeHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[1] #.so"
2 [0] #2 in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[7] #2 in in "/usr/local/OpenFOAM/OpenFOAM"-1.7.0/lib/linux64GccDPO/pt/libOpenFOAM.suo"
[5] #2 sr/local/Open in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linu in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64Fx64GccDPOpt/libOpenFOAM.so"GccDPOpt/libOpen
[6] #2 FOAM.so"
[3] #2 OAM/OpenFOA in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #2 M-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[4] #2 __restore_rt__restore_rt__restore_rt__restore_rt__ restore_rt__restore_rt__restore_rt__restore_rt at sigaction.c:0
[0] #3 Foam::Time::adjustDeltaT() at sigaction.c:0
[1] #3 Foam::Time::adjustDeltaT() at sigaction.c:0
[7] #3 Foam::Time::adjustDeltaT() at sigaction.c:0
[4] #3 Foam::Time::adjustDeltaT() at sigaction.c:0
[5] #3 Foam::Time::adjustDeltaT() at sigaction.c:0
[3] #3 Foam::Time::adjustDeltaT() at sigaction.c:0
[6] #3 Foam::Time::adjustDeltaT() at sigaction.c:0
[2] #3 Foam::Time::adjustDeltaT() in in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[1] #4 "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #4 in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[7] #4 in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[4] #4 in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[5] #4 in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/ in "/usr/lolibOpenFOcal/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[3] #4 AM.so"
[6] #4 in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #4 mainmainmainmainmainmainmainmain in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/porousInterFoam"
[0] #5 __libc_start_main in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/porousInterFoam"
[4] #5 __libc_start_main in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/porousInterFoam"
[7] #5 __libc_start_main in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/porousInterFoam"
[5] #5 __libc_start_main in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDP in "/usr/local/OpenFOAM/OpenOpt/porousInterFoam"
[3] #5 __libc_start_mainFOAM-1.7.0/applications/bin/linux64GccDPOpt/porousInterFoam"
[6] #5 __libc_start_main in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/porousInterFoam"
[1] #5 __libc_start_main in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/porousInterFoam"
[2] #5 __libc_start_main in "/lib64/libc.so.6"
[4] #6 in "/lib64/libc.so.6"
[0] #6 in "/lib64/libc.so.6"
[7] #6 in "/lib64/libc.so.6"
[5] #6 in "/lib64/libc.so.6"
[3] #6 in "/lib64/libc.so.6"
[6] #6 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/lib64/libc.so.6"
[2] #6 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) constFoam::regIOobject::writeObject(Foam::IOstream ::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) constFoam::regIOobject::writeObject(Foam::IOstream ::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/lib64/libc.so.6"
[1] #6 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) constFoam::regIOobject::writeObject(Foam::IOstream ::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/usr/local/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/porousInterFoam"
[psacae04:23489] *** Process received signal ***
[psacae04:23489] Signal: Floating point exception (8)
[psacae04:23489] Signal code: (-6)
[psacae04:23489] Failing at address: 0x44100005bc1
[psacae04:23489] [ 0] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23489] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x324e430265]
[psacae04:23489] [ 2] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23489] [ 3] /usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2ae4e65426f9]
[psacae04:23489] [ 4] porousInterFoam [0x4221ed]
[psacae04:23489] [ 5] /lib64/libc.so.6(__libc_start_main+0xf4) [0x324e41d994]
[psacae04:23489] [ 6] porousInterFoam(_ZNK4Foam11regIOobject11writeObjec tENS_8IOstream12streamFormatENS1_13versionNumberEN S1_15compressionTypeE+0xf1) [0x41f099]
[psacae04:23489] *** End of error message ***
[psacae04:23494] *** Process received signal ***
[psacae04:23494] Signal: Floating point exception (8)
[psacae04:23494] Signal code: (-6)
[psacae04:23494] Failing at address: 0x44100005bc6
[psacae04:23494] [ 0] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23494] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x324e430265]
[psacae04:23494] [ 2] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23494] [ 3] /usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2b9f967396f9]
[psacae04:23494] [ 4] porousInterFoam [0x4221ed]
[psacae04:23494] [ 5] /lib64/libc.so.6(__libc_start_main+0xf4) [0x324e41d994]
[psacae04:23494] [ 6] porousInterFoam(_ZNK4Foam11regIOobject11writeObjec tENS_8IOstream12streamFormatENS1_13versionNumberEN S1_15compressionTypeE+0xf1) [0x41f099]
[psacae04:23494] *** End of error message ***
[psacae04:23496] *** Process received signal ***
[psacae04:23496] Signal: Floating point exception (8)
[psacae04:23496] Signal code: (-6)
[psacae04:23496] Failing at address: 0x44100005bc8
[psacae04:23496] [ 0] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23496] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x324e430265]
[psacae04:23496] [ 2] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23496] [ 3] /usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2ad6fbaf96f9]
[psacae04:23496] [ 4] porousInterFoam [0x4221ed]
[psacae04:23496] [ 5] /lib64/libc.so.6(__libc_start_main+0xf4) [0x324e41d994]
[psacae04:23496] [ 6] porousInterFoam(_ZNK4Foam11regIOobject11writeObjec tENS_8IOstream12streamFormatENS1_13versionNumberEN S1_15compressionTypeE+0xf1) [0x41f099]
[psacae04:23496] *** End of error message ***
[psacae04:23495] *** Process received signal ***
[psacae04:23495] Signal: Floating point exception (8)
[psacae04:23495] Signal code: (-6)
[psacae04:23495] Failing at address: 0x44100005bc7
[psacae04:23495] [ 0] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23495] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x324e430265]
[psacae04:23495] [ 2] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23495] [ 3] /usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2b2eb99726f9]
[psacae04:23495] [ 4] porousInterFoam [0x4221ed]
[psacae04:23495] [ 5] /lib64/libc.so.6(__libc_start_main+0xf4) [0x324e41d994]
[psacae04:23495] [ 6] porousInterFoam(_ZNK4Foam11regIOobject11writeObjec tENS_8IOstream12streamFormatENS1_13versionNumberEN S1_15compressionTypeE+0xf1) [0x41f099]
[psacae04:23495] *** End of error message ***
[psacae04:23492] *** Process received signal ***
[psacae04:23492] Signal: Floating point exception (8)
[psacae04:23492] Signal code: (-6)
[psacae04:23492] Failing at address: 0x44100005bc4
[psacae04:23492] [ 0] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23492] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x324e430265]
[psacae04:23492] [ 2] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23492] [ 3] /usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2b71bec0e6f9]
[psacae04:23492] [ 4] porousInterFoam [0x4221ed]
[psacae04:23492] [ 5] /lib64/libc.so.6(__libc_start_main+0xf4) [0x324e41d994]
[psacae04:23492] [ 6] porousInterFoam(_ZNK4Foam11regIOobject11writeObjec tENS_8IOstream12streamFormatENS1_13versionNumberEN S1_15compressionTypeE+0xf1) [0x41f099]
[psacae04:23492] *** End of error message ***
[psacae04:23493] *** Process received signal ***
[psacae04:23493] Signal: Floating point exception (8)
[psacae04:23493] Signal code: (-6)
[psacae04:23493] Failing at address: 0x44100005bc5
[psacae04:23493] [ 0] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23493] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x324e430265]
[psacae04:23493] [ 2] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23493] [ 3] /usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2ace10e636f9]
[psacae04:23493] [ 4] porousInterFoam [0x4221ed]
[psacae04:23493] [ 5] /lib64/libc.so.6(__libc_start_main+0xf4) [0x324e41d994]
[psacae04:23493] [ 6] porousInterFoam(_ZNK4Foam11regIOobject11writeObjec tENS_8IOstream12streamFormatENS1_13versionNumberEN S1_15compressionTypeE+0xf1) [0x41f099]
[psacae04:23493] *** End of error message ***
[psacae04:23490] *** Process received signal ***
[psacae04:23490] Signal: Floating point exception (8)
[psacae04:23490] Signal code: (-6)
[psacae04:23490] Failing at address: 0x44100005bc2
[psacae04:23490] [ 0] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23490] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x324e430265]
[psacae04:23490] [ 2] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23490] [ 3] /usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2af5027056f9]
[psacae04:23490] [ 4] porousInterFoam [0x4221ed]
[psacae04:23490] [ 5] /lib64/libc.so.6(__libc_start_main+0xf4) [0x324e41d994]
[psacae04:23490] [ 6] porousInterFoam(_ZNK4Foam11regIOobject11writeObjec tENS_8IOstream12streamFormatENS1_13versionNumberEN S1_15compressionTypeE+0xf1) [0x41f099]
[psacae04:23490] *** End of error message ***
[psacae04:23491] *** Process received signal ***
[psacae04:23491] Signal: Floating point exception (8)
[psacae04:23491] Signal code: (-6)
[psacae04:23491] Failing at address: 0x44100005bc3
[psacae04:23491] [ 0] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23491] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x324e430265]
[psacae04:23491] [ 2] /lib64/libc.so.6 [0x324e4302d0]
[psacae04:23491] [ 3] /usr/local/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam4Time12adjustDeltaTEv+0x59) [0x2b94a66a06f9]
[psacae04:23491] [ 4] porousInterFoam [0x4221ed]
[psacae04:23491] [ 5] /lib64/libc.so.6(__libc_start_main+0xf4) [0x324e41d994]
[psacae04:23491] [ 6] porousInterFoam(_ZNK4Foam11regIOobject11writeObjec tENS_8IOstream12streamFormatENS1_13versionNumberEN S1_15compressionTypeE+0xf1) [0x41f099]
[psacae04:23491] *** End of error message ***
mpirun noticed that process rank 0 with PID 23489 on node psacae04 exited on signal 8 (Floating point exception).
Thank you
R.Kanesan
rkanesan is offline   Reply With Quote
vof transient error
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
