OF23x: Decomposing a patch into N similar parts |
November 17, 2014, 09:16 |
Rep Power: 14 |
I want to decompose my simulation domain based on one of the patches in my domain. The patch should be equally distributed to all the processors since I do some calculations on it, which take a lot longer than the flow simulation itself. So my main objective is to equally decompose this patch. Is there a way to decompose a domain based on the decomposition of one specific patch?
Thanks, Andreas |
November 17, 2014, 11:02 |
Fatema Zandi Goharrizi
Rep Power: 17 |
There are 4 methods for decomposing:
simple hierarechical scotch manual see this page: http://openfoamwiki.net/index.php/DecomposePar and I see "metis" instead of "scotch" but I know in OF 2.3.0 and 2.2.0 the second one is presented. |
November 18, 2014, 01:35 |
Rep Power: 14 |
Thanks. I know about these methods for decomposition in OF. The question is, which method I should use to decompose a domain based on the equal distribution of a patch to the number of processors.
November 18, 2014, 03:21 |
Rep Power: 17 |
hi
what you mean by decompose a patch? what is the patch? what is the geometry? in above methods there is a way to distribute the domain in equal parts. |
November 18, 2014, 03:35 |
Rep Power: 14 |
I want to decompose the cells on a patch so that each processor gets the same amount of cells from that patch. But I think that I found a workaround.
I am doing some manual decomposition. I create the decomposition file using setFields and define the processors for each cell based on their coordinates. This was described here before: http://www.cfd-online.com/Forums/ope...computing.html |
November 18, 2014, 03:48 |
#6 | ||
Rep Power: 17 |
good luck |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
[Gmsh] Single volume Mesh gmsh | PeteH | OpenFOAM Meshing & Mesh Conversion | 9 | August 6, 2013 08:54 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
