November 20, 2014, 12:03 |
Multicore/Cluster calculation does not work
christian
i have a little problem with the use of multicore/cluster calculation. Maybe anyone could help. If i try to solve my mesh with multicore it does not work only singlecore calculation works well. I use the command (mpirun -np 2 interFoam -parallel) and i always get this error.. Nodes: n<list>, e.g., n0-3,5 CPUS: c<list>, e.g., c0-3,5 Extras: h (local node), o (origin node), N (all nodes), C (all CPUs) Examples: mpirun n0-7 prog1 Executes "prog1" on nodes 0 through 7. mpirun -lamd -x FOO=bar,DISPLAY N prog2 Executes "prog2" on all nodes using the LAMD RPI. In the environment of each process, set FOO to the value "bar", and set DISPLAY to the current value. mpirun n0 N prog3 Run "prog3" on node 0, *and* all nodes. This executes *2* copies on n0. mpirun C prog4 arg1 arg2 Run "prog4" on each available CPU with command line arguments of "arg1" and "arg2". If each node has a CPU count of 1, the "C" is equivalent to "N". If at least one node has a CPU count greater than 1, LAM will run neighboring ranks of MPI_COMM_WORLD on that node. For example, if node 0 has a CPU count of 4 and node 1 has a CPU count of 2, "prog4" will have MPI_COMM_WORLD ranks 0 through 3 on n0, and ranks 4 and 5 on n1. mpirun c0 C prog5 Similar to the "prog3" example above, this runs "prog5" on CPU 0 *and* on each available CPU. This executes *2* copies on the node where CPU 0 is (i.e., n0). This is probably not a useful use of the "C" notation; it is only shown here for an example. Defaults: -c2c -w -pty -nger -nsigs does anyone knows whats this about or what could be the issue of the error? regards |
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 09:37 |
How to continue calculation after the computer is abruptly shut off? | superqtp | CFX | 5 | September 25, 2012 08:53 |
The calculation efficiency of OpenFOAM | chiven | OpenFOAM Running, Solving & CFD | 4 | September 14, 2009 04:44 |
How can I speed up my calculation? | Kim | FLUENT | 2 | June 24, 2008 13:31 |
Non-uniform grid calculation | Aspens | Main CFD Forum | 1 | February 23, 2000 14:15 |
