April 30, 2014, 06:33 |
DNS of duct flow
mjk
Rep Power: 11 |
Hello everyone
I have successfully make a DNS of channel flow with the solver given here: http://www.cfd-online.com/Forums/ope...s-2-1-0-a.html The result is good. But when I use the solver(ico—DNS)to simulate a duct flow(all the boundarys I set as wall except the inlet and outlet which I set as periodic boundary).And the value of dp/dx is 2 times of the value of channel flow case. I have changed the scheme of ddt to Euler/CN/backward.All the results are not good compared to results of Gavrilakis(1992,Direct numerical simulation of turbulent flow in a square duct). I also have refined my mesh but still failed getting a good result. Can you give me some advice? Thank you very much! I have attached my case here. regards! andersn |
May 3, 2014, 10:14 |
Niu
Rep Power: 11 |
Hi, andersn! I'm working in a duct of 1mm X 1mm, maybe there are some difference from yours . I found that the boundary condition of U in your dictionary of 0 is set as cyclic. should it be wall? i.e. fixedvalue? I have another question, How did you get the initial condition of p and U when your simulation parameters such as geometry size, and gradP changes?
May 3, 2014, 22:19 |
mjk
Rep Power: 11 |
hello Niu
To my case,the flow direction I set as periodic boundary condition.As for the initial condition of p and U,I set it according http://www.cfd-online.com/Forums/ope...s-2-1-0-a.html using the tool perturbU.what kind of your case?Are you working on duct DNS also? I have update my meshes. Code:
Domain size:6.4X1X1 grid:60*80*80 distance between first grid to wall: 0.002 the stretching ratio:1.06 Can anyone give me some suggestion? regards! andersn |
May 6, 2014, 22:14 |
Niu
Rep Power: 11 |
Hello, anderson, in a duct flow , the boundary layer of wall of normal and that of wall of spanwise is superposed at the four corner, maybe the character of turbulence here don't agree the character of channel flow, not duct flow. How much is your duct flow and men velocity streamwise?
May 14, 2014, 21:53 |
Huang Xianbei
Rep Power: 13 |
is the flow direction the only homogenous direction in the duct flow?As in channel flow, the homogenous directions are streamwise and spanwise
May 15, 2014, 21:57 |
mjk
Rep Power: 11 |
Thank you for your suggestion.what do you mean by that"only homogenous direction".In my case,the duct flow direction is along x-axis, while the other four boundaries are wall(no-slip).
May 15, 2014, 22:31 |
Huang Xianbei
Rep Power: 13 |
May 15, 2014, 23:04 |
mjk
Rep Power: 11 |
yes,The flow direction is the only homogenous direction which I use periodic boundary condition.
I have try some numerical scheme,but the rms of velocity in the flow direction is not good either(the attached files).Is it the problem of fvScheme or PISO method? why are DNS of channel flow and duct flow so different? I have been confused by it for a few weeks. regards! andersn |
May 15, 2014, 23:19 |
#9 | |
Huang Xianbei
Rep Power: 13 |
Are you sure your simulation reached fully developed? |
May 15, 2014, 23:35 |
#10 |
mjk
Rep Power: 11 |
yes.this scheme is quite different from the channel one.
But at first I use the same scheme as the channel flow.I didn't change anything except the boundary condition of spanwise which I modified to wall.And I have refined my grid also.The flow time is so long and I am sure it has reached fully developed. I have simulated the channel flow case also. And the result is good enough. |
May 15, 2014, 23:49 |
#11 | |
Huang Xianbei
Rep Power: 13 |
In my simulation, the steady state was reached after about 160000s while the deltaT=0.5s, so it's quite long |
May 16, 2014, 00:04 |
#12 |
mjk
Rep Power: 11 |
what kind of problem of yours? a duct flow or a channel flow?Can you share it with us.which solver did you use?Maybe the problem exist in fvSheme or polyMesh or something else.
May 16, 2014, 02:27 |
#13 |
Huang Xianbei
Rep Power: 13 |
May 16, 2014, 05:43 |
#14 |
Niu
Rep Power: 11 |
Hello Xianbei,
There are not homogenous in the two direction in duct flow(spanwise and normal wall). |
May 16, 2014, 05:48 |
#15 | |
Niu
Rep Power: 11 |
Did you initialize your U filed with perturbU or other ways when simulating channel flow? Best Regards! Z.Q. Niu |
May 18, 2014, 22:05 |
#16 | |
Huang Xianbei
Rep Power: 13 |
ddtSchemes { default backward; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; grad(UMean) Gauss linear;//in order to calculate vt } divSchemes { default none; div(phi,U) Gauss linear; div(phi,k) Gauss limitedLinear 1; div(phi,B) Gauss limitedLinear 1; div(B) Gauss linear; div(phi,nuTilda) Gauss limitedLinear 1; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default none; laplacian(nu,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DBEff,B) Gauss linear corrected; laplacian(DnuTildaEff,nuTilda) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } Code:
convertToMeters 1; vertices ( (0 0 0) (12.56 0 0) (0 1 0) (12.56 1 0) (0 2 0) (12.56 2 0) (0 0 6.28) (12.56 0 6.28) (0 1 6.28) (12.56 1 6.28) (0 2 6.28) (12.56 2 6.28) ); blocks ( hex (0 1 3 2 6 7 9 8) (128 64 128) simpleGrading (1 10 1) hex (2 3 5 4 8 9 11 10) (128 64 128) simpleGrading (1 0.1 1) ); edges ( ); boundary ( bottomWall { type wall; faces ((0 1 7 6)); } topWall { type wall; faces ((4 10 11 5)); } sides1_half0 { type cyclic; neighbourPatch sides1_half1; faces ((0 2 3 1)); } sides1_half1 { type cyclic; neighbourPatch sides1_half0; faces ((6 7 9 8)); } sides2_half0 { type cyclic; neighbourPatch sides2_half1; faces ((2 4 5 3)); } sides2_half1 { type cyclic; neighbourPatch sides2_half0; faces ((8 9 11 10)); } inout1_half0 { type cyclic; neighbourPatch inout1_half1; faces ((1 3 9 7)); } inout1_half1 { type cyclic; neighbourPatch inout1_half0; faces ((0 6 8 2)); } inout2_half0 { type cyclic; neighbourPatch inout2_half1; faces ((3 5 11 9)); } inout2_half1 { type cyclic; neighbourPatch inout2_half0; faces ((2 8 10 4)); } ); mergePatchPairs ( ); |
May 20, 2014, 22:01 |
#17 |
Huang Xianbei
Rep Power: 13 |
I have just got to know that the fvm used in DNS is not as accurate as spectral method. So if a fvm is used in DNS ,the mesh should be much finer. I got this from a doctor, and I want to confirm the message, if you know something about the accuracy of the two methods, please show to me
June 16, 2014, 11:09 |
#18 | |
Rep Power: 13 |
Is that helpful? I am using OpenFOAM for DNS pipe flow. I am also interested in this topic. |
June 17, 2014, 04:23 |
#19 |
Florian Ries
Rep Power: 12 |
why everybody use ico-DNS instead of pisoFoam, pimpleFoam or icoFoam for DNS in channel-flow?? These solvers should give the same results and their are still implemented in OF. kind regards Florian |
June 17, 2014, 04:52 |
#20 |
Rep Power: 13 |
I do pipe flow with pimplefoam, as it has fvOptions, which I can make pressure compensation for cyclic bc.
dns |
Display Modes | |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
flow at 15 deg. AoA over a duct - 3D case | sandy_1982 | CFX | 6 | February 28, 2013 17:46 |
Secondary Flow in Square Duct | YJ Lee | Main CFD Forum | 7 | October 13, 2012 01:49 |
Turbulent Flow in Straight Square Duct - k-ep Validation | mcclud | STAR-CCM+ | 2 | August 7, 2012 17:56 |
DNS of blasius flow for trasition | taw | Main CFD Forum | 6 | October 20, 2009 05:24 |
