tank filling (water/air), I think I messed up the BCs |
September 5, 2012, 11:39 |
tank filling (water/air), interFoam floating point exceptions
Simon Arne
Rep Power: 13 |
Final Edit:
Hi there, I had some problems with interFoam solving the filling of a tank with water. Time step is becoming super small and at some point I get a (reproduceable) floating point exception. Like this one: Code:
--> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 982 Increased the timePrecision from 215 to 216 to distinguish between timeNames at time 0.0150866 MULES: Solving for alpha1 Liquid phase volume fraction = -1.49946e-07 Min(alpha1) = -0.090619 Max(alpha1) = 1 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 982 Increased the timePrecision from 216 to 217 to distinguish between timeNames at time 0.0150866 MULES: Solving for alpha1 Liquid phase volume fraction = -1.49946e-07 Min(alpha1) = -0.090618 Max(alpha1) = 1 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 982 Increased the timePrecision from 217 to 218 to distinguish between timeNames at time 0.0150866 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0453575, No Iterations 22 time step continuity errors : sum local = 7.82082e-07, global = 4.38484e-18, cumulative = -5.46418e-07 DICPCG: Solving for p_rgh, Initial residual = 0.876617, Final residual = 0.0415977, No Iterations 80 time step continuity errors : sum local = 7.48236e-06, global = -6.87346e-10, cumulative = -5.47106e-07 DICPCG: Solving for p_rgh, Initial residual = 0.998003, Final residual = 9.97068e-08, No Iterations 518 time step continuity errors : sum local = 3.56092e-10, global = -4.13824e-14, cumulative = -5.47106e-07 ExecutionTime = 539.87 s ClockTime = 540 s Courant Number mean: 0.0559093 max: 16782.9 Interface Courant Number mean: 5.98943e-06 max: 2.26688 deltaT = 5.58971e-108 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 982 Increased the timePrecision from 218 to 219 to distinguish between timeNames at time 0.0150866 Time = 0.0150866238184654728737843498720394563861191272735595703125 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 982 Increased the timePrecision from 219 to 220 to distinguish between timeNames at time 0.0150866 MULES: Solving for alpha1 Liquid phase volume fraction = -1.49946e-07 Min(alpha1) = -0.0906142 Max(alpha1) = 1 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 982 Increased the timePrecision from 220 to 221 to distinguish between timeNames at time 0.0150866 MULES: Solving for alpha1 Liquid phase volume fraction = -1.49946e-07 Min(alpha1) = -0.0906105 Max(alpha1) = 1 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 982 Increased the timePrecision from 221 to 222 to distinguish between timeNames at time 0.0150866 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #5 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/interFoam" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/interFoam" Floating point exception - I reworked my boundaries (start with the easiest ones!) - very helpful is the depthCharge tutorial! especially to check the fvScheme and fvSolve settings! - I did a manual timeStep setting in the controlDict : this needed some trial and error to find the right setting (as it is also depending on the mesh size!) - I switched off the momentum predictor, although I am not sure how much this influenced the issues For everyone interested I attach my final case. I plan to introduce some more complex boundaries (e.g. closing valves) in the near future. The optained results are stable, although I have not physically validated them (I think I should have a look the velocity in the outlet). If you have suggestions to this, please feel free to share them. If you want to use this case, feel free to do so. Note: The attached thumbnail picture is from the very beginning. New mesh looks much much better, don't worry. Best regards, Simon Last edited by simpomann; September 8, 2012 at 08:11. |
September 8, 2012, 08:09 |
Simon Arne
Rep Power: 13 |
I just put a post to say it is solved (to push the thread up, so people who are actually interested get notified). Best regards, Simon |
August 21, 2017, 08:16 |
Help
Rep Power: 13 |
I am trying to solve water filling bottle tutorial from long back (http://www.tfd.chalmers.se/~hani/kur...Hemida_VOF.pdf). I am not getting reasonable results. I used inlet velocity as 0.1 m/sec. I am attaching my FOAM files. Please kindly let me know what mistake I am doing. |
Display Modes | |
Filling Tank with Water | leff | CFX | 7 | August 21, 2017 08:47 |
BCs to the outlet patch (filling a simple tank) | Ternox | OpenFOAM Pre-Processing | 4 | August 21, 2017 08:19 |
Pressure BCs for rasInterFoam tank fillingdraining problem | kwardle | OpenFOAM Running, Solving & CFD | 8 | September 17, 2008 15:37 |
Filling a tank or pipe | stu | CFX | 3 | May 24, 2007 19:23 |
how to set boundary condition for a tank filling w | namrata | FLUENT | 6 | May 2, 2007 11:23 |
