allenfieldin |
December 12, 2014 08:35 |
something run with runTime++: core dumped
Hi,guys,
I modified the icoFsiFoam in extend 3.0 and I came into a problem which concerns runTime++ inside the while (runTime.run()) loop, my solver code looks like this:
________________________________________________
# include "CourantNo.H"
Info<<"problem here 1 ! "<<endl;
# include "readTimeControls.H"
#include "alphaCourantNo.H"
Info<<"problem here 2 ! "<<endl;
# include "setDeltaT.H"
Info<<"problem here 3 ! "<<endl;
runTime++;
Info<<"problem here 4 ! "<<endl;
and the case log gives the following error after 20 time steps elapsed:
Courant Number mean: 0.000316668 max: 0.00608423 velocity magnitude: 0.0786566
problem here 1 !
Interface Courant Number mean: 9.70933e-06 max: 0.00164405
problem here 2 !
problem here 3 !
Segmentation fault (core dumped)
it stops without typing "problem here 3 ! ".:eek:
the interesting thing is after I change the time step to smaller values, the case still run for 20 steps!! exactly!
as I am running a FSI problem with icoFsiFoam in foam-extnd 3.0, the controlDict of the fluid part is:
application icoFsiFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 50;
deltaT 0.0005;
writeControl timeStep;
writeInterval 20;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression compressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep no;
maxCo 0.5;
maxAlphaCo 0.25;
maxDeltaT 1;
the fluid part controlDict has the same content except dropping "application icoFsiFoam;"
Can anyone tell me what happened? is the controlDict not right?
Thanks for any help and hint
/Allen
