NACA0012 Validation Accuracy Improvement
4 Attachment(s)
Hey everyone,
- I have been trying to validate NACA0012 at 0 angle of attack at Re=400,000 before going to other complicated cases. - My geometry: 5c before above and below the airfoil and 20c behind the airfoil quite standard. - Top, front and bottom of the airfoil are treated as one patch and it is the joint together as the inlet and outlet behind the airfoil is outlet. BC's U=30m/s k=0.0216, w= 9.4512, e= 0.01297, length scale l= 0.022 and turbulence intensity 0.4%. I have also tried for inlet patch TOP Code:
TOP Code:
TOP Code:
TOP Code:
Create time Here is my Fv Schemes Code:
ddtSchemes Code:
solvers Basically all was going well until I got the results, When I got the results I got good agreement with Cp distribution around the airfoil but not so great with boundary layer growth and wake which I have been trying to achieve for couple of days playing the Fv schemes and Fv solutions but the results don't even nudge for any change I make in the fv sch/sol. The Cd also is quite high 0.4 it is supposed to be 0.008 and for a 2D case what is the 'Aref' you use in the forceCoeffs dict ? Can you please advice on what mistake i could be possibly doing that is causing this variation in the boundary layer and wake validation. I have a very nice boundary layer mesh around the airfoil, no sudden changes in cell sizes measured the value of first cell size for y+1 using online calculator and used it. Here are my results for KWSST, Saplart and KE. (the image name mentions SST,Splrt & KE) |
2 Attachment(s)
Any one any suggestion ?
I have changed the y+ value to 30 and used wall functions there has been some improvement in the results but not as expected See the results posted below from Kw-SST model |
same issue
Hi alhasan
I am doing almost the exact same thing as you. My fv solutions and schemes looks the same as yours. I did not run potentalFoam first though. Sad news is i am also getting poor results. I have my y+ above 30 since i am using wall functions. I have been running this simulation for over 50000 steps. Still no convergence. Have you found out your problem and solved it as yet?? |
Yes I have found the results I had to use the right Y+ to get the boundary layer accurately, However I could not manage to get results without using the wallFunctions and with Y+ = 1 which is what I am still trying to figure out any help here for me would be still appreciated. However coming back to your problem, - for convergence potentialFoam initialisation is very important in my opinion to give you an idea with potential foam I get convergence at around 7000 time step and without for the same case sometimes even 200,000 timestep. so I strongly advice potentialFoam initialisation. - are you doing 2D or 3D simulation, and solver - can you give me checkMesh results, some images close to the wall of the mesh and what software did you use to mesh ? - you can start with a first order schemes upwind for everthing, it doesnt make much of a difference, I still got good results. - what is the reynolds number you looking at and what are the turbulence model you have tried used and how bad is your result. All the best, Hasan K.J |
1 Attachment(s)
Hi there
So i am using blockMesh to do my meshing. I am attaching the checkMesh output. I am currently only do a 2D mesh, and trying to get results similar to those posted here http://turbmodels.larc.nasa.gov/naca0012_val_sst.html So my Re = 6e6 and wind speed of 51.45m/s When i look at the cp around the foil i can see i have issues at the leading edge(LE). This is also where i have trouble with my y+ value. In blockMesh i set teh 1st cell height to be the same around the whole foil, and for the most part the y+ is greater than 30 and less than 500.. conditions for use of wall functions. But at the LE my y+ drops to around 8... so my thinking is i need to change the cell height at this section to better accommodate my wall function. You mentioned your y*/ was around 1, am i confused? I thought when i used wall functions i needed a 30 <y+< 500 |
Sorry for not being clear I was talking about two different cases, one case using Wall functions and average Y+ of 30 on the airfoil - which was good enough to validate both my Cp distribution and boundary layer growth. Second case without using wall function and average Y+ of 1 where I can validate only Cp distribution and not the boundary layer growth this I am still trying to figure out how to achieve. - there is more discussion about my particular case and how I got to the Y+ here startig from Post 16 http://www.cfd-online.com/Forums/ope...te-y-plus.html - Also spend some time on this utility here which helps define the Y+ after the first simulation. http://www.cfd-online.com/Forums/ope...lus-field.html It might be little long thread but it is worth the read. Now coming back to your case you need to choose a particular Y+ that is anything between 30 and 300 and fix it as a average Y+ around your airfoil when meshing. In my experience this has given the best result. you should start with average Y+ of 30 and carry on from there, your problem should be sorted if this is sorted in my opinion. I take you have used KW-SST by any chance did you try K-E, K-W or spallart and see how better or bad the results were ? Q. However recently I have been having problems with even Y+ 30 when I start with different angle of attacks the stagnation point is kind of smuged I dunno what is happening but with zero angle of attacks there was no such problems. All the best, Hasan K.J |
Hi Hasan
So i managed to get a good result with a 10 AoA for naca0012. I have an average y+ around the foil of 200. Again the leading edge value drops to about 8. The way i finally got a good result was a reworking of my mesh. BlockMesh is a pain to say the least. I am running a 15 AoA as a final check on my mesh. I have found the stagnation point is an issue. Os i am adjusting the y+ in the area. That said the Cl and Cd match the validation data earlier mentioned (for 10 AoA). I killed the simulation when the CL and Cd values showed stability for a decent amount of iterations. My residuals at the time were not too good though. P was sitting at 1e-4 and the Ux and Uy at 1e-5. I have seen people set their residuals down to 1e-9 for cut off.. am i being to premature in stopping my sim? Last question, what are your outlet conditions? I am using freeStream and it seems alright... If you would like i can send you my case and see if you notice anything odd about my system of constant folder. I would be willing to do the same for you too. Thanks again for your help earlier |
Hello Gareth,
What is your Cl and Cd from the simulation ?, because I have found the value changes with and without wall function. Can you please post a closee up image of the stagnation point !! I want to see what is happening with such high Y+ of 200 personally I have never crossed 100 Y+ and you need to try to validate the Cp atleast because when the stagnation point doesnt look good the Cp distribution is ususally off the charts :/ when you have time please have a look at the utilities and links provided in my previous post !! - Did you use potentialFoam and did you look at your residuals and what number of iterations are they converging, I personally have 1e-12 for K,W,U and 1e-9 for P and I get the convergence about 7000 iterations for zero angle of attack and 15000 iterations for 10 above angle of attack. only when you postprocess your results like the Cp and Boundary layer on the airfoil you will actually know if the convergence is enough. - Boundary conditions depends from case to case, It depends on case you are trying to validate. Since I do validation of experiments most of the time, I use Fixed inlet and Zerogradient outlet. sometimes even inlet-outlet at the outlet patch. that being said Cl, Cd and Cp distribution are very easy to achieve in CFD the problem is the boundary layer growth and aifoil wake validation that takes the energy out of you. Blockmesh I have never managed to mesh an airfoil in blockmesh, I use Salome free opensource software when I did not have access to ICEM, and now using ICEM to mesh airfoil which lets you contol the mesh verywell. all the best Hasan K.J |
Continuation
Hello Everyone,
The answer for the question posted by me in this thread is assigning the right Y+ value for the case, the answers were acquired from these two threads by the variant of my question from Post 16 here http://www.cfd-online.com/Forums/ope...tml#post526625 and post 52 http://www.cfd-online.com/Forums/ope...tml#post527314 Hope this saves your time, Thanks for all the answers, Hasan K.J |
