SemiImplicitSource injection rate is per timestep?
Old   December 31, 2014, 11:45
Default SemiImplicitSource injection rate is per timestep?
Derek Mitchell
derekm is on a distinguished road
When using SemiImplicitSource in FVoptions on p, li { white-space: pre-wrap; } chtMultiRegionSimpleFoam solver with field h, I became aware its effect was dependent on the timestep length.
e.g.
    scalarSemiImplicitSourceCoeffs
            volumeMode      specific;
            injectionRateSuSp
                h           (  20000 0 ); // 2e4
injects 2E4 joules per m3 per deltaT thus if you double the deltaT you will halve the Watts per m3
Please can someone confirm that this is the correct interpretation of the solveSolid.h and the resulting action is the intended one.
    for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
        fvScalarMatrix hEqn
                thermo.isotropic()
                ? -fvm::laplacian(betav*thermo.alpha(), h, "laplacian(alpha,h)")
                : -fvm::laplacian(betav*taniAlpha(), h, "laplacian(alpha,h)")
            fvOptions(rho, h)
        hEqn.relax();
        fvOptions.constrain(hEqn);
        hEqn.solve();
        fvOptions.correct(h);
thermo.correct();
Info<< "Min/max T:" << min(thermo.T()) << ' ' << max(thermo.T()) << endl;
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   January 1, 2015, 11:46
Derek Mitchell
ignore the above ... it turns out to be slow convergence in the solid regions
now at least partially fixed by changing nNonorthogonalCorrectors
and relaxationFactors in fvSolutions.
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Injection Rate JoshS. AVL FIRE 11 March 5, 2015 03:28
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Dpm injection mass flow rate diamondx FLUENT 0 November 22, 2012 13:04
DPM injection mass flow rate kingpots ANSYS 0 November 22, 2012 11:12
