Boundary Layer strange result
Old   January 14, 2015, 04:18
Default Boundary Layer strange result
daniel fernex
fernexda is on a distinguished road
Dear all,
I'm coming to you because I'm facing a boundary layer problem on a simulation...
I'm simulating a body in a flow with an inlet velocity Ux=5m/s. But right from the first iterations, the results close to the body gets strange... This can be seen on the attached pictures.
One can see that the velocity is 0 on the wall, but gets much bigger around the first cell, and then decreases again. And because of this my simulation blows up after a few iterations.
What I've done :
  • Turbulent/laminar simulation
  • Different algorithms (SIMPLE,PISO,PIMPLE, changin nCorrections and nOuterCorrections)
  • Different fvSolutions
  • Different fvSchemes (diffusive schemes for better convergence, and more accurate schemes)
  • OpenFoam 2.1 and 2.3
None of this could solve my problem. The only thing that did work is decreasing the cells' size around the wall. But my goal is to use a wall function so that I can have bigger cells (and increase the timeStep). So reducing the mesh size goes against this goal.
I'm running out of ideas, so if anyone has any hint it would be very appreciated !
Regards,
Daniel
fernexda is offline   Reply With Quote
Old   January 14, 2015, 07:07
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Daniel, what do you need, steady-state or unsteady solutions?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   January 14, 2015, 07:46
daniel fernex
Hi, thanks for the quick reply.
In the end I need an unsteady simulation with moving mesh (with pimpleDyMFoam), but the error occurs for all cases.
I am currently trying with a steady-state simulation to check the mesh convergence (minimum mesh size to have a mesh-independent solution).
Old   January 14, 2015, 07:47
Philipp
That means simpleFoam? Then post the log output of that until it becomes ugly...
Old   January 14, 2015, 08:53
daniel fernex
Yes I'm using simpleFoam.
Here a sample of the log :
Time = 319
smoothSolver:  Solving for Ux, Initial residual = 0.057221157, Final residual = 3.568287e-06, No Iterations 16
smoothSolver:  Solving for Uy, Initial residual = 0.063087545, Final residual = 4.5084555e-06, No Iterations 18
GAMG:  Solving for p, Initial residual = 0.0037987384, Final residual = 2.7417897e-07, No Iterations 23
GAMG:  Solving for p, Initial residual = 0.00020201867, Final residual = 9.5084443e-08, No Iterations 12
time step continuity errors : sum local = 1.6112304, global = -0.03484718, cumulative = -0.77715832
smoothSolver:  Solving for nuTilda, Initial residual = 0.046411558, Final residual = 4.2056708e-06, No Iterations 3
ExecutionTime = 870.68 s  ClockTime = 886 s
forces forcesPaddle0 output:
    sum of forces:
        pressure : (0 0 0)
        viscous  : (2.6813238e+13 5.6435289e+11 -1.4963997)
        porous   : (0 0 0)
    sum of moments:
        pressure : (0 0 0)
        viscous  : (-2.8217644e+11 1.3406619e+13 -2.6081707e+13)
        porous   : (0 0 0)
forceCoeffs forceCoeffsPaddle0 output:
    Cm    = -5.2163414e+11
    Cd    = 5.3626477e+11
    Cl    = 1.1287058e+10
    Cl(f) = -5.1599061e+11
    Cl(r) = 5.2727767e+11
forceCoeffs forceCoeffsPaddle1 output:
    Cm    = -96904.785
    Cd    = -66422.036
    Cl    = 297601.6
    Cl(f) = 51896.014
    Cl(r) = 245705.58
Time = 320
smoothSolver:  Solving for Ux, Initial residual = 0.052995367, Final residual = 4.8433206e-06, No Iterations 15
smoothSolver:  Solving for Uy, Initial residual = 0.062183782, Final residual = 5.6252108e-06, No Iterations 17
GAMG:  Solving for p, Initial residual = 0.0037642096, Final residual = 3.4332139e-07, No Iterations 21
GAMG:  Solving for p, Initial residual = 0.00017745207, Final residual = 5.9287776e-08, No Iterations 12
time step continuity errors : sum local = 1.085192, global = -0.02221701, cumulative = -0.79937533
smoothSolver:  Solving for nuTilda, Initial residual = 0.061514173, Final residual = 3.6499883e-06, No Iterations 3
ExecutionTime = 874.44 s  ClockTime = 890 s
    sum of forces:
        pressure : (0 0 0)
        viscous  : (3.1377491e+13 6.8424339e+11 -1.8496672)
        porous   : (0 0 0)
    sum of moments:
        pressure : (0 0 0)
        viscous  : (-3.421217e+11 1.5688745e+13 -3.0631529e+13)
        porous   : (0 0 0)
    Cm    = -6.1263058e+11
    Cd    = 6.2754982e+11
    Cl    = 1.3684868e+10
    Cl(f) = -6.0578814e+11
    Cl(r) = 6.1947301e+11
    Cm    = -114884.08
    Cd    = -78823.833
    Cl    = 351014.44
    Cl(f) = 60623.139
    Cl(r) = 290391.3
Time = 321
And some results are shown on the pictures.
And as I said, this simulation works just fine when the mesh on the BL is finer.
Old   January 14, 2015, 08:58
Philipp
1) In my experience your linear solvers take too many iterations in each outer (SIMPLE) iteration. Did you set relTol to 1e-4? This is normally not needed in SIMPLE. But fixing this will make your solver only faster... not better You can post the fvSolution to get some help.
2) Can you post checkMesh output and fvSchemes? What about your boundary conditions? Are you sure, they are correct? If not, you can post them, too.
Old   January 14, 2015, 09:18
daniel fernex
I'm rather confident about the boundary conditions. After trying many of them, the only one working are those from the motorBike example (with Spalart-Allmaras model).
The problem occurs with different schemes (accurate as well as diffusive schemes).
Same with the tolerances. I've tried with maxIter=1000 (tolerance and relTol = 0) just for fun, and it still doesn't work.
To sum up, the problem appears as soon as I increase the cells size around the body. I understand this could cause troubles with a turbulent case without using a wall function, but it also causes troubles in laminar...
Concerning the wall function, as far as I know I just have to specify the wall function in 0/nut, right ? Are the initial conditions as posted here ok considering I'm using a wall function ?
nut
|  \\    /   O peration     | Version:  2.3.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      nut;
dimensions      [ 0 2 -1 0 0 0 0 ];
internalField   uniform 0;
boundaryField
    Inlet
        type            calculated;
        value           uniform 0;
    Outlet
        type            calculated;
        value           uniform 0;
    upperSym
        type            symmetryPlane;
        value           uniform 0;
    lowerSym
        type            symmetryPlane;
        value           uniform 0;
    paddle0
        type            nutUSpaldingWallFunction;
        value           uniform 0;
    paddle1
        value           uniform 0;
    AMI_P0S
        type            cyclicAMI;
        value           $internalField;
    AMI_P1S
        type            cyclicAMI;
    AMI_SP0
        type            cyclicAMI;
    AMI_SP1
        type            cyclicAMI;
    AMI_SF
        type            cyclicAMI;
    AMI_FS
        type            cyclicAMI;
nuTilda
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nuTilda;
internalField    uniform 0.05;
//internalField   uniform 0.05;
boundaryField
    Inlet
        type            fixedValue;
        value           uniform 0.05;
    Outlet
        type            inletOutlet;
        inletValue      uniform 0.05;
        value           uniform 0.05;
    upperSym
        type            symmetryPlane;
    lowerSym
        type            symmetryPlane;
    paddle0
        type            fixedValue;
        value           uniform 0;
    paddle1
        type            fixedValue;
        value           uniform 0;
    AMI_P0S
        type            cyclicAMI;
    AMI_P1S
        type            cyclicAMI;
    AMI_SP0
        type            cyclicAMI;
    AMI_SP1
        type            cyclicAMI;
    AMI_SF
        type            cyclicAMI;
    AMI_FS
        type            cyclicAMI;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (5 0 0);
boundaryField
    Inlet
      type              fixedValue;
      value             uniform (5 0 0);
    Outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    upperSym
        type            symmetryPlane;
    lowerSym
        type            symmetryPlane;
    paddle0
        type            fixedValue;
        value           uniform (0 0 0);
    paddle1
        type            fixedValue;
    AMI_P0S
        type            cyclicAMI;
    AMI_P1S
        type            cyclicAMI;
    AMI_SP0
        type            cyclicAMI;
    AMI_SP1
        type            cyclicAMI;
    AMI_SF
        type            cyclicAMI;
    AMI_FS
        type            cyclicAMI;
p
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p;
dimensions      [ 0 2 -2 0 0 0 0 ];
boundaryField
    Inlet
        type            zeroGradient;
    Outlet
        type            fixedValue;
        value           uniform 0;
    upperSym
        type            symmetryPlane;
    lowerSym
        type            symmetryPlane;
    paddle0
        type            fixedValue;
        value           uniform 0;
    paddle1
        type            fixedValue;
        value           uniform 0;
    AMI_P0S
        type            cyclicAMI;
    AMI_P1S
        type            cyclicAMI;
    AMI_SP0
        type            cyclicAMI;
    AMI_SP1
        type            cyclicAMI;
    AMI_SF
        type            cyclicAMI;
    AMI_FS
        type            cyclicAMI;
Old   January 14, 2015, 09:20
Philipp
paddle0 and paddle1 are walls? If so, why did you set pressure to zero and not zerogradient?
Old   January 14, 2015, 09:25
daniel fernex
Oh my god............
I hadn't noticed, it the same for all simulations I've run......... I guess I'm sometimes being confused with all the files... This could definitely create problems...
I change this and I keep you posted. Thank you for seeing this !
Old   January 14, 2015, 09:28
daniel fernex
And concerning the wall function definition, do you agree on what I've put ?
Old   January 14, 2015, 09:29
Philipp
I don't use SA-model but the airfoil2d tutorial uses it the same way.
Old   January 15, 2015, 07:14
daniel fernex
Ok, that was the problem... Everything works just fine now !
I would never have thought the error could come from initial conditions... Thanks a lot for this, you saved me many hours of work !
Regards,
Daniel
Old   January 15, 2015, 07:16
Philipp
Maybe just a typo, but it should be "boundary" not "initial" conditions in your last post.
Old   January 15, 2015, 07:18
daniel fernex
You don't miss anything
It's boundary condition indeed.
Old   January 15, 2015, 07:21
Philipp
Now you can tune your solver settings to get rid of these horrible iterations. If you need any consecutive help or are not sure just post again.
boundary layer, diverging, openfoam
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] Snappy creates strange cells far away from boundary vainilreb OpenFOAM Meshing & Mesh Conversion 3 December 16, 2020 05:11
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
Divide Prismatic Boundary Layer Mesh causes overlapping faces SilentRunner42 enGrid 4 May 4, 2015 03:37
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
