Problem with Fluid-Structure-Interaction using icoFsiFoam
Hey guys,
after running the standard icoFsiFoam tutorial provided by foam extend, I decided to change the structure a little bit. Instead of one beam for the solid, I put two of them to investigate how they interact among themselves and with the fluid. So, I changed both blockMeshDict files by only adding the second beam, I didn't change anything apart this. Here is the one for the fluid: https://dl.dropboxusercontent.com/u/...MeshDict_fluid And this one is for the solid: https://dl.dropboxusercontent.com/u/...MeshDict_solid The problem is now, that it seems that only the second beam interacts with the fluid and the first one doesn't although it has to, too. http://s7.postimg.org/lwu81h7uj/Scre...0_22_56_48.png What am I doing wrong? Thanks in advance.. Harak |
