Problem with Fluid-Structure-Interaction using icoFsiFoam |
January 20, 2015, 17:23 |
Rep Power: 11 |
Hey guys,
after running the standard icoFsiFoam tutorial provided by foam extend, I decided to change the structure a little bit. Instead of one beam for the solid, I put two of them to investigate how they interact among themselves and with the fluid. So, I changed both blockMeshDict files by only adding the second beam, I didn't change anything apart this. Here is the one for the fluid: https://dl.dropboxusercontent.com/u/...MeshDict_fluid And this one is for the solid: https://dl.dropboxusercontent.com/u/...MeshDict_solid The problem is now, that it seems that only the second beam interacts with the fluid and the first one doesn't although it has to, too. What am I doing wrong? Thanks in advance.. Harak |
icofsifoam |
Fluid Structure Interaction tutorial | C12Carbon | ANSYS | 25 | November 2, 2015 03:56 |
Fluid Structure Interation Problem | Vino | Main CFD Forum | 5 | August 24, 2013 14:23 |
Hypersonic Fluid Structure Interaction with openFoam? | Ay82 | OpenFOAM Pre-Processing | 0 | February 16, 2013 18:00 |
Fluid structure interaction. | Haree | FLUENT | 2 | August 7, 2010 02:56 |
fluid structure interaction | taru agrawal | FLUENT | 4 | September 10, 2007 03:12 |
