temperature dependent thermophysicalProperties
Old   August 28, 2017, 14:26
Default temperature dependent thermophysicalProperties
guenter is on a distinguished road
I'm working on chtMultiRegionFoam and simulate the cooling of a fluid region, which is surrounded with a solid region. There are no inlets or outlets. If I use in thermophysicalProperties only constant values my simulation works. But if I want to use temperature dependent values
( I use:
transport polynomial;
thermo hPolynomial;
equationOfState icoPolynomial; )
then my simulation crashes. I found the following thread in this forum:
Introducing polynomial thermophysical properties
In this thread Praveen aksed:
This is quite an old post but I am running into similar issues with convergence in chtMultiRegionFoam with the icoPolynomial EOS model. I do have a closed liquid domain with no inlet or outlet boundaries. Is there a way to deal with such domains to account for property variations?
My question is more or less the same. How can I use temperature dependent values in closed regions and achieve convergence?
I tried to use inletOutlet boundary conditions for U and p_rgh. Then the simulation runs, but the cooling is to fast and unrealistic.
Thank you very much.
guenter is offline   Reply With Quote
OpenFOAM solver for incompressible BUT temperature dependent flow niko0807 OpenFOAM Running, Solving & CFD 2 October 27, 2015 05:31
Temperature dependent properties lcbuijs OpenFOAM Pre-Processing 4 June 26, 2015 19:28
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
UDF: temperature dependent BC ehooi FLUENT 6 January 22, 2011 12:26
Temperature dependent Stick-to-Wall jrunsten CFX 7 August 2, 2010 08:04
