Viscoelastic Tutorials running problem
Old   January 28, 2015, 12:46
Default Viscoelastic Tutorials running problem
mojtaba
cliff is on a distinguished road
Hi Foamers, while running a viscoelastic tutorial from viscoelasticfluidfoam solver i came up with this error
| \\ / O peration | Version: 2.3.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.1-bcfaaa7b8660
Exec : blockMesh
Date : Jan 28 2015
Time : 20:14:15
Host : "sepinood-Inspiron-N5010"
PID : 27458
Case : /opt/openfoam231/tutorials/viscoelastic/viscoelasticFluidFoam/DCPP/constant/polyMesh
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM FATAL IO ERROR:
cannot find file
file: /opt/openfoam231/tutorials/viscoelastic/viscoelasticFluidFoam/DCPP/constant/polyMesh/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
i would appreciate your help. Thanks
cliff is offline   Reply With Quote
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 13:30
[Other] Problem running after decomposition paul.m.edwards OpenFOAM Meshing & Mesh Conversion 0 January 14, 2015 12:55
[ICEM] wing body tutorials, problem zxin ANSYS Meshing & Geometry 8 March 22, 2011 01:05
paraFoam running problem Aleksey_R OpenFOAM 2 November 27, 2009 18:18
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
