Segmentation fault with particleTracks
Old   November 9, 2012, 18:11
Default Segmentation fault with particleTracks
gmagoon is on a distinguished road
I'm trying to generate particle tracks using the particleTracks utility from trajectories obtained from solidParticleFoam.
The output ends with the following:
Time = 39400.897
    Reading particle positions
    Read 682 particles
Time = 39400.898
    Read 682 particles
Time = 39400.899
    Read 682 particles
Time = 39400.9
    Read 682 particles
Particle statistics:
    Found 0 particles originating from processor 0
Generating 0 particle tracks for cloud defaultCloud
Time = 39400
    Constructing tracks
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
 in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/particleTracks"
#4  __libc_start_main in "/lib/libc.so.6"
Segmentation fault
This is using 1 processor and OpenFoam 2.1.0.
My particleTracksProperties file:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      particleTrackProperties;
cloudName       defaultCloud;
sampleFrequency 1;
maxPositions    1000000;
Any tips in figuring out what I might be doing wrong are appreciated.
I can try to provide any additional information that would help in diagnosing the problem.
Thanks in advance,
Greg
gmagoon is offline   Reply With Quote
Old   November 12, 2012, 10:13
I have just now tried to run this using the gdb debugger. The results aren't particularly informative to me (looks like the crash is in the main() function), but my hope is that they will be meaningful to someone else:
Time = 39400
    Constructing tracks
Program received signal SIGSEGV, Segmentation fault.
0x00000000004098f0 in main ()
(gdb) where
#0  0x00000000004098f0 in main ()
Old   February 22, 2013, 14:24
I think I've figured out the problem and came up with a way to address this.
I added some debugging lines to determined that was related to insufficient origId information; the code was storing -1 for all the IDs and the code was crashing on the line "if (allTracks[trackId].size() < maxPositions)" with trackId equal to -1. It turns out that I wasn't aware of the need for origId and origProcId files when I ran solidParticleFoam (which I used to generate the trajectories); solidParticleFoam didn't seem to require origID or origProcID in the 0/lagrangian/defaultCloud directory (actually, technically, I'm using 39400 as starting time here), and when I ran solidParticleFoam, it filled subsequent time directories with "1000{-1}" and "1000{0}" for these files, respectively.
If I instead put origID and origProcID in the 0/lagrangian/defaultCloud directory, filled with contents like shown below, before running solidParticleFoam, then subsequent use of particleTracks works fine, and without error.
FoamFile
    version     2.0;
    format      ascii;
    class       labelField;
    location    "39400";
    object      origId;
1000
0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
FoamFile
    version     2.0;
    format      ascii;
    class       labelField;
    location    "39400";
    object      origProcId;
1000
0
0
0
0
0
0
0
0
0
For context, there seems to be a similar issue that can be encountered when changing the number of processors that are used (http://www.openfoam.org/mantisbt/view.php?id=419), but this is unrelated, and wasn't an issue in my case.
Old   February 7, 2015, 08:56
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
I have a similar problem.
But your solution didn't work on mine.
I am using DPMFoam on OF 2.3.
neither it worked on my own solver in which I added particle tracking library into icoFoam.
In both serial and parallel runs I get the following error:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::coordSet::scalarCoord(int) const at ??:?
#4  Foam::writer<double>::writeTable(Foam::coordSet const&, Foam::List<Foam::List<double> const*> const&, Foam::Ostream&) const at ??:?
#5  Foam::rawSetWriter<double>::write(bool, Foam::PtrList<Foam::coordSet> const&, Foam::List<Foam::word> const&, Foam::List<Foam::List<Foam::Field<double> > > const&, Foam::Ostream&) const at ??:?
 at ??:?
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Segmentation fault (core dumped)
origId and origProcId are as follows for a sample time step:
origId:
9(0 1 2 3 4 5 6 7 8)
origProcId:
9{0}
I even added both "origId" and "origProcId" into the "0" time step, but no success.
Here is my particleTrackProperties file:
cloudName       kinematicCloud;
sampleFrequency 1;
maxPositions    9;
setFormat       csv;    // see sampleDict for set formats
Thanks.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is online now   Reply With Quote
Old   February 7, 2015, 09:10
Mojtaba.a's Avatar
I think I found a solution.
Changing the setFormat into vtk seems to solve the problem.
However I don't know why raw or csv formats don't work yet.
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 15:06
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 14:38
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 07:23
segmentation fault usker Siemens 5 March 5, 2007 23:14
