Problem - simulation crashes by changing flow velocity |
February 2, 2015, 11:20 |
Rep Power: 11 |
Hi foamers,
I've modified the icoFsiFoam tutorial so that I have two beams one after the other. I want to investigate how the second one affects the flow field. The original flow velocity at the inlet was 4 m/s but I have to change it to 1.5 m/s because the simulation crashes - too high Courant numbers. What do I have to change to make the simulation possible to run with 4 m/s or even higher inlet velocities? I've already adjusted the time step dynamically with adjustableRunTime and set the maximal Courant number to be 0.5. Thanks in advance! Harak |
February 2, 2015, 11:33 |
What is a value of your initial time step? |
February 2, 2015, 12:20 |
Rep Power: 11 |
Hi alexeym,
Thanks for the quick reply. This is how my controlDict looks like: Code:
application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 15; deltaT 0.0003; writeControl adjustableRunTime; writeInterval 0.006; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression compressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.5; maxDeltaT 1; |
February 2, 2015, 12:23 |
OK. Now find minimum cell size of your mesh, take your initial time step and calculate Co. |
February 2, 2015, 12:32 |
Rep Power: 11 |
Hi again,
Do you mean I have to look for my smallest cell size of my mesh? In this case it is 0.00636324. |
February 2, 2015, 12:45 |
Well, I meant that you need to calculate Courant number using your inlet velocity, initial time step and minimum mesh cell size (in fact min(Vi/Ai)).
So questions: 1. What happens if you reduce deltaT (let's say 1e-5) instead of inlet velocity? 2. Though mesh seems to be fine, can you post checkMesh output? 3. Can you post actual error message? 4. Your initial and boundary conditions? |
February 2, 2015, 16:02 |
Rep Power: 11 |
I really appreciate your help!
What does min(Vi/Ai) mean? Is it the smallest cell size in x and y-direction? 1. I tried it with 1e-5 and with the original inlet velocity and it crashes. https://dl.dropboxusercontent.com/u/...log.icoFsiFoam 2. This is checkMesh: Code:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 16982 internal points: 0 faces: 33090 internal faces: 16110 cells: 8200 faces per cell: 6 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 8200 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology consoleFluid 90 184 ok (non-closed singly connected) topWall 210 422 ok (non-closed singly connected) bottomWall 200 406 ok (non-closed singly connected) outlet 40 82 ok (non-closed singly connected) inlet 40 82 ok (non-closed singly connected) defaultFaces 16400 16982 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 0 -0.1) (6 1 0.1) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (-4.80596e-18 2.03681e-17 -5.57077e-16) OK. Max cell openness = 2.07536e-16 OK. Max aspect ratio = 10.3374 OK. Minimum face area = 8.80291e-05. Maximum face area = 0.0246864. Face area magnitudes OK. Min volume = 1.76058e-05. Max volume = 0.00147382. Total volume = 1.188. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.3789e-10 OK. Coupled point location match (average 0) OK. Mesh OK. End 4. motionU Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { consoleFluid { type fixedValue; value uniform (0 0 0); } topWall { type slip; } bottomWall { type slip; } outlet { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (0 0 0); } frontAndBackPlanes { type empty; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { consoleFluid { type zeroGradient; } topWall { type zeroGradient; } bottomWall { type zeroGradient; } outlet { type totalPressure; p0 uniform 0; U U; phi phi; rho none; psi none; gamma 1; value uniform 0; } inlet { type zeroGradient; } frontAndBackPlanes { type empty; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { consoleFluid { type movingWallVelocity; value uniform (0 0 0); } topWall { type fixedValue; value uniform (0 0 0); } bottomWall { type fixedValue; value uniform (0 0 0); } outlet { type zeroGradient; } inlet { type fixedValue; value uniform (4 0 0); } frontAndBackPlanes { type empty; } } |
February 3, 2015, 03:43 |
1. Yes, it is minimum size of the mesh in x or y direction. Here's how OpenFOAM calculates Courant number: Code:
CoNum = 0.5*gMax(sumPhi/mesh.V().field())*runTime.deltaTValue(); Code:
writeControl timeStep; writeInterval 1; |
February 3, 2015, 05:44 |
Olivier
hello,
You use totalPressure for p at outlet, so you should use pressure(InletOutlet, ...)Velocity BC familly for U at outlet too. regards, olivier |
February 3, 2015, 06:38 |
Rep Power: 11 |
So, with 4 m/s and timeStep for writeControl and 1 for writeInterval I get the following velocity distribution:
t=1e-5 t=2e-5 t=3e-5 After here, it crashes again. And again logfile: https://dl.dropboxusercontent.com/u/...tydistribution @olivierG What kind of BC would you suggest? |
February 3, 2015, 07:02 |
#11 |
Olivier
hello,
Just try pressureInletOutletVelocity. regards, olivier |
February 3, 2015, 07:17 |
#12 |
Rep Power: 11 |
Just like this?
0/U Code:
outlet { type pressureInletOutletVelocity; value uniform (0 0 0); } |
February 4, 2015, 07:35 |
#13 | |
Rep Power: 11 |
Have you had the opportunity to have a look at my case? I'm stuck.. Really appreciate your help! Thanks. Harak |
February 4, 2015, 07:55 |
#14 |
Change of BC did not help? Please attach archive of the case, it'll be simpler; guess there no NDA as you've posted mesh and screenshots. |
February 4, 2015, 08:51 |
#15 |
Rep Power: 11 |
Unfortunately, it didn't.
In this configuration I can only run the simulation at 1.5 m/s. And another question: Why does the simulation crash, too, when I change the E-Module in the mechanicalProperties in solid? For example from 2e+6 to 2e+3. I would be stranded without your help! Thanks in advance |
February 12, 2015, 07:27 |
#16 |
Rep Power: 11 |
February 12, 2015, 08:10 |
#18 |
Andrew Smith
Rep Power: 11 |
I did not know about the NDA
Thanx man |
February 12, 2015, 10:10 |
#19 | |
Rep Power: 11 |
I talked to my supervisor regarding this problem and he assumed that it could be because of my limited computer ressources (I've got an old Notebook with 4GB RAM). As soon foam-extend is installed on the super-computers of my department, I'll try to run it over there. Maybe it was just as easy as that I'll let you know |
February 13, 2015, 00:26 |
#20 |
Andrew Smith
Rep Power: 11 |
Really, is it system limitation?
Advice: Your mesh can be handled with present system configuration |
courant number, icofsifoam |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Domain format problem on airfoil flow simulation | andrenonaka | CFX | 14 | December 7, 2015 01:42 |
Solidworks Flow Simulation, Problem with Point Goals | TomSteventon | FloEFD, FloWorks & FloTHERM | 2 | February 8, 2012 12:02 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 03:13 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
