Re doubt calculation and classification high-low |
December 24, 2018, 03:07 |
Nicola D'Ettole
Rep Power: 7 |
i have to analyze a rectangular duct L= 124[mm] h=3[mm]. Liquid=water , U=10 [m/s] - For the calculation of Re i have to use hydraulic diamter or h ? - Re =57000 is high o low Reynolds Number ? trying different turbulences model i found a lot of difference beetwen high and low re models..... -what turbulence model do you suggest ? For similar problem with L=1390[mm] h= 3[mm] ... can i consider it as a duct ? |
December 25, 2018, 10:17 |
ANKUR GARG
Rep Power: 9 |
I just know that you must use h for the calculation of Re. What is the viscosity value in your case?
Ankur Garg |
December 26, 2018, 06:17 |
Nicola D'Ettole
Rep Power: 7 |
Kinematic viscosity is 1e-6.
December 26, 2018, 08:44 |
ANKUR GARG
Rep Power: 9 |
In that case your Re is 30,000 (high). Which is more than enough for a turbulent flow to occur inside a rectangular duct. I don't have any idea with respect to turbulence model though!
Ankur Garg |
Display Modes | |
