Fabf |
February 16, 2015 05:53 |
buoyantPimpleFoam - pressure field
2 Attachment(s)
Dear Foamers,
simulation case: thermal water storage which is loaded with hot fluid. Imagine a cylindrical tank with horizontal radial inlet/outlet discs near top resp. bottom.
Problem is the pressure field distribution. According to p = p_rgh + rho*gh pressure decreases correctly with height (nice explanation here. But at the bottom p equals 1e5 Pa so that there is negative pressure at the top. Since all pressure gradients are okay and density is just a function of temperature, there are no converging issues and the results are reasonable. But still, where does it come from?
My p_rgh-file:
internalField uniform 1e5;
boundaryField
"(SYMM_F|SYMM_B)"
type wedge;
"(OUTLET)"
type prghPressure;
rhoName rho;
p uniform 1e5;
"(INLET)"
type zeroGradient;
"(WALL_DIFF|WALL_DIFF_MASTER|WALL_DIFF_SLAVE|WALL_SIDE|WALL_TOP)"
type fixedFluxPressure;
value $internalField;
p-file:
boundaryField
"(SYMM_F|SYMM_B)"
type wedge;
"(OUTLET|INLET|WALL_TOP|WALL_DIFF|WALL_DIFF_MASTER|WALL_SIDE|WALL_DIFF_SLAVE)"
type calculated;
I tried the following:
- change all values of p and p_rgh = 1e5 to rho*g*h with h - height of tank--> gives a pressure field close to reality (pressure at top is around 1e5Pa), but I am not really happy with that solution..
- apply a fixed pressure p_rgh=1e5 to the top wall (lid), keep U=(0 0 0) --> outflow through wall, although wall has fixed value to zero for U
- initialize with correct pressure field using funkySetFields (according to here--> same field after some timesteps
- trying different BCs.. --> same
- try setting presure reference point --> only yields for closed systems
What I am missing? From a physical point of view: internal field of p_rgh has to be around atmospheric pressure, since the hydrostatic component is applied afterwards. Also my outlet pressure has to be p_rgh=1e5Pa ..?!
my other files:
-thermophysicalProperties
thermoType
type heRhoThermo;
mixture pureMixture;
transport polynomial;
thermo hPolynomial;
equationOfState icoPolynomial;
specie specie;
energy sensibleEnthalpy;
dtdp = off;
specie
nMoles 1;
molWeight 18;
equationOfState
rhoCoeffs<8> (-540.4680832401600000 16.7586613589465000 -0.0668647676334458 0.0001178920951103 -0.0000000809669445 0 0 0 );
thermodynamics //f(T)
Hf 0;
Sf 0;
CpCoeffs<8> (4193.0 0 0 0 0 0 0 0);
muCoeffs<8>
( 0.260216875208536 -0.0029069831827857 0.0000122820941795 -0.0000000231946446 0.0000000000164938 0 0 0); //
kappaCoeffs<8>
( 0.596 0 0 0 0 0 0 0);
fvSolution:
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"rho.*"
solver GAMG;//PCG;
//preconditioner DIC;
tolerance 1e-6;//0;
relTol 0;
p_rgh
solver GAMG;//PCG;
tolerance 1e-6;//1e-8;
relTol 0.01;
smoother GaussSeidel;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
p_rghFinal
$p_rgh;
relTol 0;
"(U|h|e|k|R|omega)"//"(U|h|e|k|epsilon|R)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-8; // 6; http://www.dicat.unige.it/guerrero/of2014b/12tipsandtricks.pdf
relTol 0.0;//.1
"(U|h|e|k|R|omega)Final"//"(U|h|e|k|epsilon|R)Final"
$U;
relTol 0;
omega
solver smoothSolver;
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
PIMPLE
momentumPredictor yes;
nOuterCorrectors 50;//1
nCorrectors 2;//2
nNonOrthogonalCorrectors 2;//20;//0;
//pRefPoint (5,39 1.79 0);
//pRefValue 1e5;;
residualControl
p_rgh
tolerance 1e-03;
relTol 0;
absTol 0;
relaxationFactors
fields
p 0.3; //0.3
"p_rhg*" 0.3;//0.3
rho 0.7;
equations
"U*" 0.7; //0.7
"T*" 0.7; //0.7
"(h|e)" 0.7; //0.7
k 0.7; //0.7
omega 0.7; //0.7
fvSchemes:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,h) Gauss upwind;
div(phi,e) Gauss upwind;
div(phi,k) Gauss upwind;
//div(phi,epsilon) Gauss upwind; k-E Modell
div(phi,omega) bounded Gauss upwind;
div(phi,R) Gauss upwind;
div(phi,K) Gauss linear;
div(phi,Ekp) Gauss linear;
div(R) Gauss linear;
//(div((muEff*dev2(T(grad(U))))) Gauss linear; k-E Modell
div(phiv,p) Gauss upwind p;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p_rgh;
Thanks in advance!
