problem with torque using sixDoFRigidBodyMotion
Dear all,
I'm using waveDyMFoam solver with sixDoFRigidBodyMotion option, to study a rotating device moving in water. I would impose a constant torque to the shaft: I added the line with torque string in the "dynamicMeshDict" file , but it seems that the defined torque is used only as an initial condition and not as a constant value imposed. Anyone know the reason of the error and how to fix it? Many thanks in advanced. Code:
sixDoFRigidBodyMotionCoeffs |
I think it should be defined under entry 'Restraints'.
However I am not sure how to make the resistant torque constant. |
Hi everyone,
I am having a problem using matlab in openvibe. I followed the steps mentioned in the tutorial but still getting an error. For example, when trying to implement tutorial 2, this is what I get. What do you think?? |
