Wrong pressure output. Correct BC for U and p?
Like Tree2Likes
  • 2 Post By Svensen
Old   February 19, 2015, 03:12
Default Wrong pressure output. Correct BC for U and p?
pizzaspinate is on a distinguished road
Hi FOAMers,
I try to simulate a wing flying in the air using potentialFoam (I assume I have to use it if I want to run a simple Euler run?!). I did have a look at the tutorials for the motorbike and 2dmoving wing in order to get the BCs right.
However I am still not entirely sure about the BCs (see attachment) in the 0/p and 0/U file as the results I am getting are funny. Especially for p which ranges from 0 to 1e-16.
Hope someone can help me out.
pizzaspinate is offline   Reply With Quote
Old   February 20, 2015, 03:54
Svensen is on a distinguished road
potentialFoam doesn't change the pressure.
"p which ranges from 0 to 1e-16" - it's simply ParaView try to make a map with some range for you, that's why it give you another value for pressure like 1e-16.
the task of potentialFoam is to define the internal field for velocity. So if you see the results of the potentialFoam you can find that you have now a non-uniform internal field with a lot of values inside
paka and sharonyue like this.
Svensen is offline   Reply With Quote
Old   February 23, 2015, 09:34
thank you very much for your help! I ran it with k-omega now and I get proper results!
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 16:29
Setting up the pressure variation due to tornado in a duct(UDF)+animation guillaume1990 FLUENT 0 March 3, 2014 11:59
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
tank sloshing - getting wrong pressure enghamed CFX 2 April 26, 2011 22:09
