problems with interDyMFoam
Old   December 15, 2009, 11:38
Default problems with interDyMFoam
Axel Mohr
alexm is on a distinguished road
hello together,
i still try to simulate the motion of a body with interDyMFoam. For this I'm using openFOAM 1.6.x. The example case 'floatingObject' (dynamicFvMesh dynamicMotionSolverFvMesh) works well (using Allrun).
But when building my own modell, using the example case as a 'template', interDyMFoam stops with following output:
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementLaplacian
--> FOAM FATAL ERROR:
Not Implemented
Trying to construct an genericFvPatchField on patch floatingObject of field cellDisplacement
From function genericFvPatchField<Type>::genericFvPatchField(con st fvPatch& p, const DimensionedField<Type, volMesh>& iF)
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 45.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/of16/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
and so on ....
what I've did:
1. blockMesh (two patches: stationaryWalls & atmosphere)
2. snappyHexMesh (to cut the simple quadratic body -> floatingObject)
3. setFields
4. interDyMFoam
for me it seems as if something is missing ... but what?
Any idea?
Thanks in advance ...
Greetings and bye, Axel
alexm is offline   Reply With Quote
Old   December 17, 2009, 20:11
Axel Mohr
again ... my mistake. I've just found it ...
I forgot to add one library in in the system/controlDict .
Good night!
Old   March 19, 2010, 06:50
Claus Meister
idrama is on a distinguished road
Hey alexm,
I saw you are using interDyMFoam. Do you create your meshes with snappyhexmes? if so, could you please explain how to you avoid polyhedras.
Cheers in advanced
idrama is offline   Reply With Quote
Old   March 5, 2015, 14:37
anonymous
Mahyar Javidi is on a distinguished road
HI every body
I have a problem in compiling a new solver developed based on interDyMFoam. I get no error in the compiling process and I get .dep file but when I use $FOAM_USER_APPBIN, I do not see my new solver in the list. By the way, I am using openFOAM 2.1.x
Any ideas?
Regards
Mahyar
Mahyar Javidi is offline   Reply With Quote
Old   March 5, 2015, 15:09
anonymous
Hi again
For more info on the above message, I ran a case using that new solver but I could not see the results in paraview.
By using the paraFoam command I get this error:
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1175
dlopen error : /home/mahyar/OpenFOAM/mahyar-2.1.x/platforms/linux64GccDPOpt/lib/libuserparticleVolumFraction.so: undefined symbol: _ZN4Foam14viscosityModel30dictionaryConstructorTab lePtr_E
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96
could not load "libuserparticleVolumFraction.so"
fileName::stripInvalid() called for invalid fileName UntitledFolder
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
Any Comments?
Thanks
Mahyar
floatingobject, interdymfoam
interDyMFoam, problems in mesh motion solutor run in parallel DLC OpenFOAM 11 December 11, 2012 02:20
Problems with reconstructPar after run interDyMFoam FG_HSRM OpenFOAM 3 December 13, 2011 11:16
Problems in mesh motion solutor in parallel 4 interDyMFoam. DLC Main CFD Forum 0 November 21, 2009 16:17
Problems in mesh motion solutor in parallel 4 interDyMFoam. DLC OpenFOAM 0 November 21, 2009 08:54
Problems with interDyMFoam myheroisalex OpenFOAM 4 September 22, 2009 19:02
