Euler Euler Water Spray in air
I want to simulate a spray of water in a chamber filled with air using the Eulerian model. Is there a solver in OpenFoam for this two-phase problem ? I would like to see the macroscopic behavior of the spray such as penetration depth and spread of the spray for different temperature and pressure of the air chamber. Thank you! |
bump
twoPhaseEulerFoam is the appropriate solver to use. It follows the eulerian eulerian approach for multiphase flows
i am having one doubt. can twoPhaseEulerFoam capture the primary breakup zone in atomization process?? |
