Buoyantboussinesq simpleFoam residuals problem
1 Attachment(s)
Hi foamers,
I m simulating a room with a inlet and outlet and a rectangular patch called lighting on the ceiling and cube inside the room. As a first basic simulation I wanted to specify heat flux boundary condition for the patch and temperature to the inlet air and velocity at the inlet pressure at outlet by pressure i mean (p_rhg) as p is calculated at the outlet. problem: 1. i did a couple of simulation but in both the simulations i get a huge fluctuatioin in the residuals graph. i have attached the picture below. I m attaching my fvscheme and fvsoluion here : FV scheme ddtSchemes { default steadyState; } gradSchemes { default leastSquares; // it was Gauss linear } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); // was bounded Gauss upwind which is first order but linearupwind is second order //div(phi,U) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,T) bounded Gauss linearUpwind grad(T); //div(phi,T) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div(phi,R) bounded Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) bounded Gauss upwind; div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p_rgh ; } // ************************************************** *********************** // FV solution: solvers { p_rgh { solver PCG; preconditioner DIC; tolerance 1e-8; relTol 0.001; } "(U|T|k|epsilon|omega|R)" { solver PBiCG; preconditioner DILU; tolerance 1e-8; // before 1e-05 relTol 0.001; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; /*residualControl { p_rgh 1e-2; U 1e-4; T 1e-2; // possibly check turbulence fields "(k|epsilon|omega)" 1e-3; }*/ } relaxationFactors { fields { p_rgh 0.3; //before it was 0.7 } equations { U 0.7; // before it was 0.3 T 0.5; "(k|epsilon|omega|R)" 0.7; } } sorry for the long question. Additionally i didnot get the correct results for the simulation. could someone please enlighten me. thankyou With Regards, Naresh Yathuru |
Hi Naresh Yathuru,
It seems that you didn't achieve convergence for your problem. So instead of posting fvSolutions and fvSchemes, it would be better to post your boundary conditions. I suggest you to use the 1st order upwind scheme for the divergence therms unless you achieve convergence. You may use [ code] text [ /code] (without spaces) when posting pieces of code. :) Regards, |
Thank you so much thiago. I think my alphat,epsillon,k,nu,Omega B.C are fine. could you please have a look at my p, p-rgh, u, T
FoamFile Code:
FoamFile Code:
version 2.0; Code:
dimensions [0 1 -1 0 0 0 0]; http://www.cfd-online.com/Forums/ope...le-case-2.html I may not be good in programming but i m good in sharing information :) Thats all i can contribute for OF users. regards, Naresh |
By the way i m using OF 230. i dont know if the TurbulentHeatFluxTemperature bug is fixed in OF 231.
Naresh |
Hi Naresh,
Unfortunately I don't have much to contribute, but I woud suggest you to use the fixedFluxPressure as inlet BC for p_rgh (see here and here) and zeroGredient for oulet BC for p_rgh. I don't know much about the lightingwall BC, but I suggest you to first try a fixedValue BC and see if the problem converges and then change this BC (a step by step thing :)) Regards, |
2 Attachment(s)
hi thiago,
Thank for your reply. I have a very crucial question i hope you could help me. I m sorry for asking it in the same thread. I m using buoyantBoussinesqsimple Foam. i m using the turbulentHeatFluxTemperature which is not giving me the reselt i expected (image attached) 1. does the turbulentHeatFluxTemperature really has a bug to be concerned about? If yes then i really surprised that no one found it out untill now except bruno untill nov 2014. 2. if not could u please check if my boundary conditions are correct. as u can see from my boundar condition for temperature. the temperature cannot be greater than 293 K. I m totally confused. where is the problem . is it because of the heatflux b.C or any other boundary condition. I ran the same simulation in fluent the results are fine. then i tried to simulate with temperature boundary condition for the lightingwall then every thing was fine. 3. is there another possibility to specify the heat flux B.c? :( Thank you in advance, naresh |
Hi Nares,
Answering your questions: 1. I really don't know, but is always better do use the latest versions to avoid problems with bugs already solved. 2. The suggestions I have were that of my last post. I only solved closed problems in OF, so I've never dealt with inlet or oulet BC. 3. You can use the fixedGradient BC to specify a fixed heat flux. Regards, |
