Simple doesn't stop after convergence criteria is achieved
Like Tree1Likes
  • 1 Post By alexeym
Old   April 2, 2015, 09:37
Default Simple doesn't stop after convergence criteria is achieved
Thiago Parente Lima
thiagopl is on a distinguished road
I'm using the chtMultiRegionSimpleFoam to simulate the problem of a enclosure vertically heated and cooled with an internal solid.
As I show bellow, even after all the convergence criteria is achieved (10^-6) the Simple algorithm doesn't stop.
I can't see the rho residuals, but I've changed it to 10^-3 and the results are the same. Why doesn't it stop?
Log showing all the residuals bellow the criteria convergence:
Time = 2216
Solving for fluid region air
DILUPBiCG:  Solving for Ux, Initial residual = 4.163122729918927e-09, Final residual = 4.163122729918927e-09, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 4.59032787455036e-09, Final residual = 4.59032787455036e-09, No Iterations 0
DILUPBiCG:  Solving for h, Initial residual = 9.416101596905256e-07, Final residual = 9.416101596905256e-07, No Iterations 0
Min/max T:300 310
DICPCG:  Solving for p_rgh, Initial residual = 9.343214257414049e-07, Final residual = 9.343214257414049e-07, No Iterations 0
time step continuity errors : sum local = 2.758594777251156e-07, global = -1.499279134027018e-17, cumulative = 1.340309069704447e-15
Min/max rho:1.123451097280091 1.160905661033402
Solving for solid region body
DICPCG:  Solving for h, Initial residual = 8.686132203851212e-07, Final residual = 8.686132203851212e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 303.7710276494997 max(T) [0 0 0 1 0 0 0] 306.1953321209988
ExecutionTime = 75.23 s  ClockTime = 75 s
Here is the fvSoltuion for the air region:
solvers
    rho
       solver          PCG
       preconditioner  DIC;
       tolerance       1e-4;
       relTol          0.1;
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-6;
        relTol          0.1; //0.01
    "(U|h|k|epsilon)"
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-6;
        relTol           0; //0.1
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       1e5;
    rhoMin          rhoMin [1 -3 0 0 0] 0.2;
    rhoMax          rhoMax [1 -3 0 0 0] 2;
    residualControl
    	p_rgh           1e-6;
    	U               1e-6;
    	h               1e-6;
	rho		1e-4;
Here is the fvSoltuion for the solid region:
solvers
    h
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0;	//0.1
SIMPLE
    residualControl
       h               1e-6;
relaxationFactors
    fields
    equations
        h               1;
Fields of interest: buoyantFoam, chtMultRegionFoam.
thiagopl is offline   Reply With Quote
Old   April 2, 2015, 09:47
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
If you check source code of the solver, it does not check for convergence. runTime.loop() (loop method of Time class) just checks if time reached endTime.
    while (runTime.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        forAll(fluidRegions, i)
            Info<< "\nSolving for fluid region "
                << fluidRegions[i].name() << endl;
            #include "setRegionFluidFields.H"
            #include "readFluidMultiRegionSIMPLEControls.H"
            #include "solveFluid.H"
        forAll(solidRegions, i)
            Info<< "\nSolving for solid region "
                << solidRegions[i].name() << endl;
            #include "setRegionSolidFields.H"
            #include "readSolidMultiRegionSIMPLEControls.H"
            #include "solveSolid.H"
        runTime.write();
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
lav likes this.
alexeym is offline   Reply With Quote
Old   April 2, 2015, 10:01
Thiago Parente Lima
Hmm... so it was a dumb question.
I believe that there is a way to modify it, but I still can't read the codes of the solvers.
Thank you.
PS: Why not check for convergence?
Old   April 2, 2015, 10:29
Alexey Matveichev
Well, it was correct question though it was not a question about OpenFOAM but a question of OpenFOAM's consistency. It is quite obvious that user expects similar behavior from SIMPLE family of solvers.
And, in fact, modification of the solver would be rather simple.
Unfortunately simpleControl has only loop public method that does a little bit more than just checking convergence. And there is criteriaSatisfied method which is protected but does just what is necessary to check convergence. So you can create myOwnSimpleControl class, which is simpleControl child. In this class you create public converged method. It just returns result criteriaSatisfied method.
Then in addition to creation of the meshes for all regions you create myOwnSimpleControl objects for every mesh. Finally you create boolean allRegionsConverged and check convergence of the regions in forAll loops.
SIMPLE: no convergence criteria found Gennaro OpenFOAM Programming & Development 3 October 21, 2018 00:08
Setting up additional convergence criteria: output parameters are ‘constant’ Pierre1 FLUENT 3 March 23, 2015 09:47
Convergence criteria PrandtlGlawert FLUENT 1 August 13, 2009 18:06
How stop simulation if convergence is not reached? Andreas FLUENT 0 October 16, 2007 12:35
Physical convergence criteria yogui FLUENT 0 April 27, 2005 08:34
