Problem with parallel run
Hello everyone,
I'm using ihfoam to simulate a wave flume. I've done some runs in parallel without any problem but now i'm doing a new one and, when i use the command reconstructPar, i get this error message Time = 14.65 Reconstructing FV fields Reconstructing volScalarFields p nut --> FOAM FATAL IO ERROR: error in IOstream "/home/antonio/IHFOAM/IHFOAM_materials/tutorials/OF222/Klopman_bicromatico/Klopman-kepsilon/processor1/14.65/nut" for operation operator>>(Istream&, List<T>&) : reading entry file: /home/antonio/IHFOAM/IHFOAM_materials/tutorials/OF222/Klopman_bicromatico/Klopman-kepsilon/processor1/14.65/nut at line 1357. From function IOstream::fatalCheck(const char*) const in file db/IOstreams/IOstreams/IOstream.C at line 114. FOAM exiting The first time i got this mistake it was for time = 30 s and i thought that maybe something had gone wrong when doing the simulation so I deleted everything and did the simulation again. Again i got this error message, this time for time = 14.65 s. I really don't know why this happens because every file in the case folder is a copy from cases that already have worked correctly. Additionally, when running ihFoam i get no error at all, only when reconstructing. Any ideia on why is this happening? Thanks António |
