Segmentation fault decomposing in a certain number of CPU (runs fine with other ncpu)
Hi everybody
I have a case I'm trying to solve. The case runs correctly when I launch on one core.
However when I launch it on multiple cores this is what i find in the standard output:
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : pimpleFoam -parallel
Date : Apr 01 2015
Time : 13:27:21
Host : "n08"
PID : 14194
Case : /home/amerio/Catherine_blocks_noSpires_narrow2
nProcs : 8
Slaves :
7
"n08.14195"
"n08.14196"
"n08.14197"
"n08.14198"
"n08.14199"
"n08.14200"
"n08.14201"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
and this is what i find in the standard error:
[5] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ost
ream&)[1] #0 Foam::error::printStack(Foam::Ostream&)[4] #0 Foam::error::printStack(Foa
m::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so"
[5] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux6
4GccDPOpt/lib/libOpenFOAM.so"
[0] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux6
[1] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux6
[4] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux6
[5] #2 in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2 in "/lib/x86_64-linux-gnu/libc.so.6"
[5] #3 Foam::processorPolyPatch::updateMesh(Foam::PstreamBuffers&) in "/lib/x86_64-linu
x-gnu/libc.so.6"
[0] #3 Foam::processorPolyPatch::updateMesh(Foam::PstreamBuffers&) in "/opt/OpenFOAM/Op
[4] #2 in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #2 in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[5] #4 Foam::polyBoundaryMesh::updateMesh() in "/lib/x86_64-linux-gnu/libc.so.6"
[4] #3 Foam::processorPolyPatch::updateMesh(Foam::PstreamBuffers&) in "/lib/x86_64-linu
x-gnu/libc.so.6"
[1] #3 Foam::processorPolyPatch::updateMesh(Foam::PstreamBuffers&) in "/opt/OpenFOAM/Op
[0] #4 Foam::polyBoundaryMesh::updateMesh() in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/
[5] #5 Foam::polyMesh::polyMesh(Foam::IOobject const&) in "/opt/OpenFOAM/OpenFOAM-2.3.0
[4] #4 Foam::polyBoundaryMesh::updateMesh() in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/
[1] #4 Foam::polyBoundaryMesh::updateMesh() in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/
[0] #5 Foam::polyMesh::polyMesh(Foam::IOobject const&) in "/opt/OpenFOAM/OpenFOAM-2.3.0
[4] #5 Foam::polyMesh::polyMesh(Foam::IOobject const&) in "/opt/OpenFOAM/OpenFOAM-2.3.0
[5] #6 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/opt/OpenFOAM/OpenFOAM-2.3.0/pla
[1] #5 Foam::polyMesh::polyMesh(Foam::IOobject const&) in "/opt/OpenFOAM/OpenFOAM-2.3.0
[0] #6 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/opt/OpenFOAM/OpenFOAM-2.3.0/pla
[4] #6 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/opt/OpenFOAM/OpenFOAM-2.3.0/pla
[1] #6 Foam::fvMesh::fvMesh(Foam::IOobject const&) in "/opt/OpenFOAM/OpenFOAM-2.3.0/pla
tforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[5] #7
in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[0] #7 in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.
so"
[4] #7 [5] in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/pimpleFoam"
[5] #8 __libc_start_main
[5] #9 in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.
so"
[1] #7 [0] in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/pimpleFoam"
[0] #8 __libc_start_main[4] in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt
/bin/pimpleFoam"
[4] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #9
[4] #9
[1] in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/pimpleFoam"
[1] #8 __libc_start_main[5] in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt
/bin/pimpleFoam"
[n08:13738] *** Process received signal ***
[n08:13738] Signal: Segmentation fault (11)
[n08:13738] Signal code: (-6)
[n08:13738] Failing at address: 0x3ed000035aa
[n08:13738] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x321e0) [0x7f75652211e0]
[n08:13738] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f7565221165]
[n08:13738] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x321e0) [0x7f75652211e0]
[n08:13738] [ 3] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so(_ZN4Foam18processorPolyPatch10updateMeshERNS_14PstreamBuffersE+0x2b5) [0x7f75663cfc95
[n08:13738] [ 4] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so(_ZN4Foam16polyBoundaryMesh10updateMeshEv+0x2b9) [0x7f75663d7729]
[n08:13738] [ 5] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so(_ZN4Foam8polyMeshC1ERKNS_8IOobjectE+0xd47) [0x7f7566426027]
[n08:13738] [ 6] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVol
ume.so(_ZN4Foam6fvMeshC2ERKNS_8IOobjectE+0x19) [0x7f7567e54319]
[n08:13738] [ 7] pimpleFoam() [0x428154]
[n08:13738] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xfd) [0x7f756520dead
[n08:13738] [ 9] pimpleFoam() [0x42b66d]
[n08:13738] *** End of error message ***
[n08:13733] *** Process received signal ***
[n08:13733] Signal: Segmentation fault (11)
[n08:13733] Signal code: (-6)
[n08:13733] Failing at address: 0x3ed000035a5
[n08:13733] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x321e0) [0x7f325085f1e0]
[n08:13733] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f325085f165]
[n08:13733] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x321e0) [0x7f325085f1e0]
[n08:13733] [ 3] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so(_ZN4Foam18processorPolyPatch10updateMeshERNS_14PstreamBuffersE+0x2bd) [0x7f3251a0dc9d
[n08:13733] [ 4] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so(_ZN4Foam16polyBoundaryMesh10updateMeshEv+0x2b9) [0x7f3251a15729]
[n08:13733] [ 5] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so(_ZN4Foam8polyMeshC1ERKNS_8IOobjectE+0xd47) [0x7f3251a64027]
[n08:13733] [ 6] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVol
ume.so(_ZN4Foam6fvMeshC2ERKNS_8IOobjectE+0x19) [0x7f3253492319]
[n08:13733] [ 7] pimpleFoam() [0x428154]
[n08:13733] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xfd) [0x7f325084bead
[n08:13733] [ 9] pimpleFoam() [0x42b66d]
[n08:13733] *** End of error message ***
[4] in "/opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/bin/pimpleFoam"
[n08:13737] *** Process received signal ***
[n08:13737] Signal: Segmentation fault (11)
[n08:13737] Signal code: (-6)
[n08:13737] Failing at address: 0x3ed000035a9
[1] #9
[n08:13737] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x321e0) [0x7f956738b1e0]
[n08:13737] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f956738b165]
[n08:13737] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x321e0) [0x7f956738b1e0]
[n08:13737] [ 3] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so(_ZN4Foam18processorPolyPatch10updateMeshERNS_14PstreamBuffersE+0x2bd) [0x7f9568539c9d
[n08:13737] [ 4] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so(_ZN4Foam16polyBoundaryMesh10updateMeshEv+0x2b9) [0x7f9568541729]
[n08:13737] [ 5] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
so(_ZN4Foam8polyMeshC1ERKNS_8IOobjectE+0xd47) [0x7f9568590027]
[n08:13737] [ 6] /opt/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVol
ume.so(_ZN4Foam6fvMeshC2ERKNS_8IOobjectE+0x19) [0x7f9569fbe319]
[n08:13737] [ 7] pimpleFoam() [0x428154]
[n08:13737] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xfd) [0x7f9567377ead
[n08:13737] [ 9] pimpleFoam() [0x42b66d]
[n08:13737] *** End of error message ***
mpirun noticed that process rank 5 with PID 13738 on node n08 exited on signal 11 (Segme
ntation fault).
To run in parallel I do the common practice
renumberMesh -overwrite
snappyHexMesh -overwrite
potentialFoam -noFunctionObjects
decomposePar
mpirun pimpleFoam -parallel
I already run a case almost identical correctly. I just slightly modified the snappyHexMesh dictionary in order to expand a refinement region that was including part of the mesh to include within it the whole mesh.
CheckMesh returns no error, while checkMesh -allGeometry returns this failure:
***Concave cells (using face planes) found, number of cells: 35616
Before snappyHexMesh the mesh is COMPLETELY structured with a non ortogonality close to the machine error. snappy only refines some areas and only the castellatedMesh step is set to true.
What could be the cause of that segmentation fault?
The case is running on a unix cluster running SMP Debian 3.2.65-1+deb7u1 x86_64.
