April 13, 2015, 05:06 |
icoDyMFoam with non-Orthogonality Check
Mathi
Rep Power: 11 |
I'm using icoDyMFoam for a moving Mesh without topological changes. In order to control the mesh-Quality during the run I want to use checkMesh while running icoDyMFoam. So is the non-Orthogonality check already done with icoDyMFoam and if so, how can I simlply use it? I want icoDyMFoam to stop the run if non-Orthogonality exceeds a particular threshold. thanks for help |
April 22, 2015, 09:07 |
Mathi
Rep Power: 11 |
some additional info: I am using foam extend 3.1
I tried this so far: in the solver icoDyMFoam.C I added the lines Code:
# include "checkVolContinuity.H" if (runTime.timeIndex()) { mesh.checkMesh(true); } Code of icoDyMFoam.C (added lines coloured green): Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | foam-extend: Open Source CFD \\ / O peration | \\ / A nd | For copyright notice see file Copyright \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of foam-extend. foam-extend is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. foam-extend is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with foam-extend. If not, see <http://www.gnu.org/licenses/>. Application icoDyMFoam Description Transient solver for incompressible, laminar flow of Newtonian fluids with dynamic mesh. Author Hrvoje Jasak, Wikki Ltd. All rights reserved. \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "dynamicFvMesh.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createTime.H" # include "createDynamicFvMesh.H" # include "initContinuityErrs.H" # include "initTotalVolume.H" # include "createFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.run()) { # include "readControls.H" # include "checkTotalVolume.H" // Make the fluxes absolute fvc::makeAbsolute(phi, U); # include "CourantNo.H" # include "setDeltaT.H" runTime++; Info<< "Time = " << runTime.timeName() << nl << endl; bool meshChanged = mesh.update(); reduce(meshChanged, orOp<bool>()); # include "volContinuity.H" if (correctPhi && (mesh.moving() || meshChanged)) { // Fluxes will be corrected to absolute velocity // HJ, 6/Feb/2009 # include "correctPhi.H" } // Make the fluxes relative to the mesh motion fvc::makeRelative(phi, U); if (mesh.moving() && checkMeshCourantNo) { # include "meshCourantNo.H" } # include "UEqn.H" // --- PISO loop for (int corr = 0; corr < nCorr; corr++) { rAU = 1.0/UEqn.A(); U = rAU*UEqn.H(); phi = (fvc::interpolate(U) & mesh.Sf()); //+ fvc::ddtPhiCorr(rAU, U, phi); adjustPhi(phi, U, p); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix pEqn ( fvm::laplacian(rAU, p) == fvc::div(phi) ); pEqn.setReference(pRefCell, pRefValue); if (corr == nCorr - 1 && nonOrth == nNonOrthCorr) { pEqn.solve(mesh.solutionDict().solver(p.name() + "Final")); } else { pEqn.solve(mesh.solutionDict().solver(p.name())); } if (nonOrth == nNonOrthCorr) { phi -= pEqn.flux(); } } # include "continuityErrs.H" // Make the fluxes relative to the mesh motion fvc::makeRelative(phi, U); U -= rAU*fvc::grad(p); U.correctBoundaryConditions(); } # include "checkVolContinuity.H" if (runTime.timeIndex()) { mesh.checkMesh(true); } runTime.write(); } Info<< "End\n" << endl; return(0); } // ************************************************************************* // My question is now what to do if I only need the information about the non-Orthogonality of the mesh? How can I get only the relevant variable? Any help appreciated Mathi |
April 29, 2015, 11:08 |
Mathi
Rep Power: 11 |
Ok, now I use the following code to get the wanted information: Code:
mesh.checkFaceOrthogonality(true) if (runTime.timeIndex()) { mesh.checkMesh(true); } in the function checkFaceOrthogonality() there is a variable used, called "minDDotS" I want to use this variable in an if condition. Can anybody tell me how to get this variable in the main function of icoDyMFoam.C? |
checkmesh, icodymfoam, moving mesh, non-orthogonality |
Orthogonality of cell check | nkjsimulating | ANSA | 6 | November 26, 2013 10:31 |
[ICEM] Understanding check mesh output | kotimari | ANSYS Meshing & Geometry | 0 | July 15, 2012 08:33 |
faceZones and topological check | mturcios777 | OpenFOAM Programming & Development | 0 | June 15, 2012 13:48 |
Automated check for convergence | Chander | CFX | 3 | May 2, 2012 18:07 |
Cell check and Boundary check errors | AB | Siemens | 4 | October 28, 2004 13:04 |
