Thermophysical problems in simpleReactingParcelFoam |
April 20, 2015, 09:59 |
Andreas V.
Rep Power: 11 |
Hi everybody
I am trying to simulate a particle flow along a tube (like the vertical channel). The flow is compressible and exactly here is my problem. If I keep my boundary condition like a incompressible flow (same inlet and outlet condition the simulation works good. As soon as I change the parameter to a compressible flow I got problems with the thermo physics. Code:
--> FOAM FATAL ERROR: Maximum number of iterations exceeded From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>::T(double, double, double, double (Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>::*)(double) const) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so" #3 Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::polynomialTransport<Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>, 8> > > >::calculate() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" #4 Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::polynomialTransport<Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>, 8> > > >::correct() in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libreactionThermophysicalModels.so" #5 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleReactingParcelFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleReactingParcelFoam" Aborted (core dumped) Should be not complicated for someone who is more experienced like me. The simpleReactingParcelFoamIPM foder is attached. Regards, Andreas |
May 3, 2016, 04:45 |
#2 | |
Ping Chang
Rep Power: 10 |
May 3, 2016, 04:47 |
Andreas V.
Rep Power: 11 |
May 3, 2016, 22:38 |
Ping Chang
Rep Power: 10 |
you said when you kept your boundary condition like an incompressible flow, the simulation worked well, in my case , I just need to simulate the incompressible flow for steady-state, but after I changed my BC ,it can only work for 45 steps. I am quite new of OF, so I have no idea what's wrong with my case. Could you tell me how did you set your BC as the incompressible. Could you help me with that? thank you very much The attachment is my case.
simpleReactingParcelFoam Case.tar.gz |
May 3, 2016, 23:20 |
Ping Chang
Rep Power: 10 |
May 4, 2016, 16:22 |
Rep Power: 16 |
I had a very quick look inside your case. I realizied that you are using p=0 as outlet condition. So I think you assumed this to be the relative pressure like it is common for incompressible cases. But very likely you need to define the pressure level for that solver with absolute pressue so e.g. for environment conditions p=100000. (Check also tutorial case here: https://github.com/OpenFOAM/OpenFOAM...calChannel/0/p Kind regards and good luck Chrisi |
May 4, 2016, 20:12 |
#7 | |
Ping Chang
Rep Power: 10 |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[mesh manipulation] Problems with rotational cyclic boundaries | TReviol | OpenFOAM Meshing & Mesh Conversion | 8 | July 11, 2014 03:45 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 11:00 |
