April 23, 2015, 11:17 |
Changing to CGS units
riccardo maione
Rep Power: 11 |
Hello all,
I am trying to run openfoam with CGS units. All my initial conditions are in cgs, so pressure is 10^6 g/cm/s^2 (dimensions [1 -1 -2 0 ...]) and velocity in cm/s (dimensions [0 1 -1 0...]) , to solve a flow in a fluidised bed with air, in order to do so I added in the controlDict DimensionedConstants { unitSet CGS; // SI; // USCS; // CGSCoeffs { universal { c c [ 0 1 -1 0 0 0 0 ] 2.99792e+10; // speed of light in vacuum (cm/s) G G [ -1 3 -2 0 0 0 0 ] 6.67429e-8; // gravitational constant (cm^3/(gs^2)) h h [ 1 2 -1 0 0 0 0 ] 6.62607e-27; // Planck's constant (erg.s) R R [1 2 -2 -1 -1 0 0 ] 8.314e7; //universal gas constant (erg/mol*K) } electromagnetic { e e [ 0 0 1 0 0 1 0 ] 4.803204e-10; // elementary charge (statcoulomb) R R [1 2 -2 -1 -1 0 0 ] 8.314e7; //universal gas constant } atomic { me me [ 1 0 0 0 0 0 0 ] 9.10938e-28; // electron mass (g) mp mp [ 1 0 0 0 0 0 0 ] 1.67262e-24; // proton mass (g) } physicoChemical { mu mu [ 1 0 0 0 0 0 0 ] 1.66054e-24; // atomic mass unit (g) k k [ 1 2 -2 -1 0 0 0 ] 1.38065e-16; // Boltzman constant (erg/K) } standard { //- Standard pressure [bar] Pstd Pstd [ 1 -1 -2 0 0 0 0 ] 1000000; // 1 bar (barye) //- Standard temperature [degK] Tstd Tstd [ 0 0 0 1 0 0 0 ] 298.15; // should be same as in SI unit system } } } however when trying to run the case the density is like 10, when it should be 1e-3. what is the matter? someone has already done this passage and knows how to help? every help is greatly appriciated, Riccardo Last edited by riccardomaione; April 24, 2015 at 09:39. |
April 24, 2015, 10:28 |
riccardo maione
Rep Power: 11 |
noone knows how to pass from SI to another unit system?
April 24, 2015, 10:36 |
And how do you set initial conditions in your simulation? |
April 24, 2015, 12:05 |
riccardo maione
Rep Power: 11 |
I used the input in CGS, so pressure is 1e6 barye and velocity inlet is 5 cm/s. Unfortunately I need this type of input because I have to couple it with a DEM program and I have been playing quite a lot in order to understand what isn't right
funny thing is that if I use the CGS constants and I set the SI input output (so the initial conditions are in SI) with the control dictionary, adding this to the controlDict: DimensionSets { unitSet SI; // USCS SICoeffs { // Basic units kg kg [ 1 0 0 0 0 0 0 ] 1.0; m m [ 0 1 0 0 0 0 0 ] 1.0; s s [ 0 0 1 0 0 0 0 ] 1.0; K K [ 0 0 0 1 0 0 0 ] 1.0; mol mol [ 0 0 0 0 1 0 0 ] 1.0; A A [ 0 0 0 0 0 1 0 ] 1.0; Cd Cd [ 0 0 0 0 0 0 1 ] 1.0; // Derived units Hz Hz [ s^-1 ] 1.0; N N [ kg m s^-2 ] 1.0; Pa Pa [ N m^-2 ] 1.0; J J [ N m ] 1.0; W W [ J s^-1 ] 1.0; // Some non-symbolic ones area area [m^2] 1.0; volume volume [m^3] 1.0; density density [ kg m^-3 ] 1.0; acceleration acceleration [ m s^-2 ] 1.0; kinematicPressure kinematicPressure [ Pa density^-1 ] 1.0; // Scaled units. Only allowed in dimensionedType (dimensionedScalar, // dimensionedVector etc.) and UniformDimensionedField, not // in DimensionedField or GeometricField cm cm [ m ] 1e-2; mm mm [ m ] 1e-3; km km [ m ] 1e3; // Set of units used for printing. Can be any basic or derived // but not scaled (only supported for dimensionedScalar, etc) writeUnits (kg m s K mol A Cd); } } density is ok and 1 kg/m^3. However in order to understand what is going on, I used a string to output the universal gas constant. In this case the constant is ok with the correct value in CGS, but its dimensionality is in Kg and m! I am a little frustrated , somebody knows what's going on? thank you for your reply Riccardo Last edited by riccardomaione; April 30, 2015 at 03:31. |
Thermophysical Property Units | johanz | OpenFOAM Pre-Processing | 2 | December 16, 2018 10:08 |
[PyFoam] Problems with the new PyFoam release | zfaraday | OpenFOAM Community Contributions | 13 | December 9, 2014 18:58 |
[PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 07:18 |
changing units in gambit | Brendan | FLUENT | 2 | August 13, 2012 09:12 |
Changing units in AVL Fire | zaer | AVL FIRE | 2 | July 18, 2012 00:27 |
