Conditions in which yPlus does not matter
Old   April 24, 2015, 05:07
Default Conditions in which yPlus does not matter
Rubén
Yuby is on a distinguished road
Hi FOAMers!
I am running a turbulence case of an incompressible flow around a rotating disc. The yPlusRAS utility gives me this values:
Patch 5 named cuerpo y+ : min: 0.0062716 max: 42.1937 average: 3.33432
Patch 6 named bordes y+ : min: 0.0042175 max: 15.3098 average: 2.02145
It's very difficult to get the yPlus you want, as it is a rotating geometry the wall shear stresses vary too much. I have spent months with snappyhexmesh...
My question is: Does a combination of turbulence model+boundary conditions at the walls/wall function exist in which the yPlus value doesn't matter?
As I have read, omegaWallfunction can change from Low-Re to High-Re, but in this thread is not completely clear: http://www.cfd-online.com/Forums/ope...omega-sst.html The paper of Menter agrees.
So, I am a little bit worried, because I don't know what to do. In this paper http://www.tfd.chalmers.se/~hani/kur...DES-Report.pdf, the only wall function they use is the omegaWallfunction, and they don't talk about yPlus, so I don't know if it does matter....
Can you help me? I would like to finish my thesis, but I am confused..
Thank you very much in advance !!!
Yuby is offline   Reply With Quote
Old   April 24, 2015, 05:19
Rubén
My current boundary conditions are:
kinetic energy:
  GNU nano 2.2.6                      Archivo: 0.org/k
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      k;
#include        "include/initialConditions"
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $turbulentKE;
boundaryField
     inlet
        type            fixedValue;
        value           uniform $turbulentKE;
    outlet
        type            zeroGradient;
    cuerpo
        type            kqRWallFunction;
        value           $turbulentKE;
    bordes
        value           $turbulentKE;
    #include "include/frontBackUpperPatches"
Omega:
  GNU nano 2.2.6                      Archivo: omega
|  \\    /   O peration     | Version:  2.3.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform $turbulentOmega;
boundaryField
    inlet
        type            fixedValue;
        value           uniform $turbulentOmega;
    outlet
        type            zeroGradient;
    cuerpo
        type            omegaWallFunction;
    bordes
nuT:
  GNU nano 2.2.6                       Archivo: nut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    cuerpo
        type            nutkWallFunction;
        value           uniform 0;
    bordes
        value           uniform 0;
frontBackUpperPatches:
  GNU nano 2.2.6                 Archivo: frontBackUpperPatches
top
    type slip;
bottom
    type slip;
frontandback
    type slip;
initialconditions:
  GNU nano 2.2.6                  Archivo: initialConditions
//Para un Re= 270000
flowVelocity         (15 0 0);
//6 revoluciones por segundo, de Flight Dynamics Measurements on an Instrumented Frisbee
//Ralph D Lorenz
//Lunar and Planetary Laboratory,
//University of Arizona
omegadisk            37.7;
pressure             0;
//turbulentKE=(3/2)*(UI)˛
//Para U=15; I=0.005;
//turbulentKE=k=0.02434614
turbulentKE          0.0084375;
//http://www.cfd-online.com/Tools/turbulence.php
//http://www.esi-cfd.com/faq/index.php?action=artikel&cat=4&id=156&artlang=en
turbulentOmega       1125;
#inputMode           merge
for a Standard k-omega model
Old   April 24, 2015, 07:23
romant's Avatar
Roman Thiele
romant is on a distinguished road
Originally Posted by Yuby View Post
Hi FOAMers!
There are no RANS turbulence models which depend on y+ on one way other another. However, you could try to use the approach described in post 3 of the thread that you mentioned http://www.cfd-online.com/Forums/ope...tml#post306339 with the nutUSpaldingWallFunction for nut.
~roman
romant is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
hexagonal boundary conditions s_h Main CFD Forum 0 August 9, 2009 22:15
Modeling new matter! Sunil Hadap Main CFD Forum 2 February 23, 2000 17:06
